Old 10-24-2012, 02:33 AM   #1
Default SWorkZ S350 BK1 X-System and Balance Weights
I searched some optional parts for Sworkz BK1 and I found the X-System and those Balance weights, they´re expensive, but do they work? Do you recommend me to buy them?
Thanks!
Daniel 15 is offline   Reply With Quote
Old 10-24-2012, 04:52 AM   #2
tak4's Avatar
Thanks!
I currently run the SWorkz but have no experience with the X-system. I use coins and (proper) tyre balancing weights to balance the car's weight if needed. Might be better to ask your question here though.
SWorkz S 350BK
Nova powered MP9 Tki3
Hobbywing powered Kyosho MP9e (Tki3)
Orion powered Xray T4'14
Driven with Sanwa M12
tak4 is offline   Reply With Quote
Old 10-25-2012, 06:27 AM   #3
Fletch7276's Avatar
I'm a new Sworkz owner myself, but bought from a guy that has a lot of experience with the chassis. I think neither is critical for performance or function. X-drive basically eliminates additional pins in the linkage (main line into diffs), and also adds an additional bearing for less play and longer wear.
Tak4 is right, the BK1 thread has feedback from folks running it.
The weights are a quick add if you want a better balanced chassis as-is. you can also consider moving the battery box forward. again, feedback from folks is the performance changes are minimal.
KYOSHO MP9 TKI3 - RB WS9, Savox 1256/1258T, AKA Impact
SWORKZ S350 BK1 - RB BX, Savox 1256/1258T, VP PRO 803
LOSI 8IGHT 2.0E - Tekin RX8, T8 2650kv
LOSI SCTE 1.0 - Castle MMP, Tekin T8 2650kv, TLR kit, Proline Holeshots
Fletch7276 is offline   Reply With Quote
Old 10-28-2012, 05:58 AM   #4
t0ddy_44's Avatar
The new radio tray will eliminate the need for added weight..
As previously stated the xdrive does eliminate a potential failure.. I have ran the 'x' hard over the last few months and have had top reliability!!!
t0ddy_44 is offline   Reply With Quote
