Old 09-30-2012, 07:23 PM   #1
associatedguy25's Avatar
Default rc8t steering
Any one know of a longer servo horn or any way i can get the steering to go lock to lock with out the link hitting the side of the servo
Serpent 811 2.0 and 811t team associated b4.2 and sc10 Houston's Engine Service Novarossi Futaba VP Powermaster SAVOX YA DIGG
associatedguy25 is offline   Reply With Quote
Old 09-30-2012, 07:34 PM   #2
tc5 man's Avatar
Yea its the way the front end supension is designed i think not sure. The only way to get the most throw is add some toe out or toe in. And increase the Throw EPA to where the servo doesnt move and where the servo turnbuckle doesnt hit the servo case at full throw. I know when i ran my RC8TCE as nitro it would be a issue running the longer servo horn.
Are you talking about when the wheels are on the ground or off ?
I got lucky with my RC8Tce converted i run the Tekno chassis and the radio box hump is shorter than the stock one so i run a longer servo arm.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 10-01-2012, 07:17 AM   #3
t4ftracer's Avatar
Trader Rating: 73 (100%+)
You can use a longer aluminum arm to gain more throw, however you will need to dremel away material from the battery box cover for clearance. You can then install some foam inside the box to keep dirt out. It will require cleaning regularly by opening up and blowing it out, which I do every race anyway to take the battery out for balance charging.
Here is a pic of Maifields truck...
He is using a robitronic arm, but they are also available from answer and protek
Thank you for your support: Team Associated, Reedy, AKA, Murnan Modified Motors, Airtronics, Lovell's Lids, Avid, Upgrade.
Gregg Rieck (Gunnar's Pit Man)
t4ftracer is offline   Reply With Quote
Old 10-02-2012, 07:18 AM   #4
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
You could also move the steering link to the top of the servo horn,
it does put the link at a pretty good angle, but will work. Did it to mine and the Losi I had. Might even do it to the Kyosho I got.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Teufel Racing is offline   Reply With Quote
Old 10-02-2012, 10:11 AM   #5
tc5 man's Avatar
I thought about doing that but the angle it puts it at not sure . Seems like it will stress the servo out.
Old 10-02-2012, 03:55 PM   #6
I didn't see an issue with over stressing the servo, stressing the bellcrank where the like mounts could, but I never had an issue that I could tell. Never broke the plastic, so I just left it as it was. Worth trying.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Old 10-05-2012, 10:04 AM   #7
Yeah i did that at the track but it got too dark to run but i will try it tomorrow for midwest nitro finals but im kinda over the whole associated kick next year ill be running a serpent
RC8T steering??? trap121 Electric Off-Road 17 09-05-2009 08:41 AM
