Old 09-24-2012, 04:04 PM   #1
Precision1's Avatar
Trader Rating: 40 (100%+)
Questions?? Truggy set up question (Hudy)
So I have a Hudy station and it calls for using a 30mm block under the chassis when setting everything up.
Is this (30mm dimension) based on a buggy? Since the trug has bigger wheels, and more ride height, should I be using a taller block when setting it up?
I know it is not a huge deal, but might as well do it right if you have the right tools! I work with 0.0005" all day long and tend to get a bit "precise" with the RC.
Precision1 is offline   Reply With Quote
Old 09-25-2012, 12:23 AM   #2
30mm block should be fine as long as it raises the chassis up far enough so that nothing touches the setup board.
The important part is that you use the same repeatable steps when using the setup kit.
Also, using 30mm blocks matches the droop gauge from hudy.
"If you have complete control over the damned thing, you're not going fast enough."
kaan is offline   Reply With Quote
Old 09-25-2012, 12:27 AM   #3
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
they work fine until you have to set your droop and they are no longer high enough
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 09-25-2012, 05:25 AM   #4
Nitro Tiger's Avatar
How do you measure your droop Tix?
Wade Lazich- NSW 1/8 IC State Delegate.
Thankyou for your support- Werks Racing USA/ Pro Rc Supplies/ Aka Aust./ Ryper Hobbies
LRD- Australian distributor of Werks Race Blend 30% fuel. Dedicated solely to the supply of racing products for 1/8 scale nitro Rc. -lazrd.com.au-
Nitro Tiger is offline   Reply With Quote
Old 09-25-2012, 08:00 AM   #5
Zerodefect's Avatar
LOLz.
The tires aren't on when you use the setup station! So how could their size influence anything at all? LOL. 30mm is a referance point to the chassis. Truggies often have similar droop and suspension travel as buggies. The system hold the car up around 30mm usually.
Yes, use the 30mm blocks. Keep in mind that your usual ride ht is often a mm or two less than those blocks, so that you may need to add camber to compensate.
Use the 30mm blocks when you set droop as well.
Setting everything up the 1st time, is easier with no shocks on the car.
My buggy (26/30mm) uses an extra degree of camber in the front when on the station than it reads on the table. 2.5-3.5/3-4 are my usual range of camber settings on the Hudy station.
Zerodefect is offline   Reply With Quote
Old 09-25-2012, 12:24 PM   #6
TIX
TIX's Avatar
I use shock length on the truggy
Alan Nankervis.
Hot Bodies D8 Truggy Greg B Nitro Off-Road 10028 08-16-2017 05:44 PM
Team Associated 1/8 scale Truggy Info and Tips Kevin Boyle Nitro Off-Road 4504 01-05-2017 06:52 PM
GT class car and Setup Station question MiniMeRCRacing Nitro On-Road 12 09-20-2010 04:09 PM
