Old 09-19-2012, 04:43 AM   #1
Default Need brake help pls
Mornin All, I've got an old Tamiya Nitrage that I'm tryin to keep runnin, and now stoppin. The brake is goin south and as Tamiya no longer has the parts, I need to find a brake rotor and discs. The Outside diameter of the rotor is 40mm,it is 1mm thick and the center is shaped like the center output dogbone cup(flat on 2 sides and round on the other sides). Does anyone know of other brake rotors that have similar configurations? I think the HPI Savage pads will work but I also want a rotor. I've found rotors with the right center but the diameter is too small. Any help would be greatly appreciated.
-Goat-
If you can read this, thank a teacher. If you can read this in English, thank those who have served our country.
-Goat- is offline   Reply With Quote
Old 09-19-2012, 08:36 AM   #2
R/C Lidz's Avatar
Trader Rating: 53 (100%+)
Send a message via MSN to R/C Lidz
found several different hits on Google...
Josh Langness
RC8T/ OS Speed/ 2060
RC8/ OS Speed/ 2060
FTGT/ MT12
BLitZ/ Castle SCT
R/C Lidz is offline   Reply With Quote
Old 09-19-2012, 11:44 AM   #3
Interesting..I have been able to previously find the entire brake system but it costs over 30 US dollars. As I'm actually looking mainly for the rotor, I would like to find something less expensive and more readily available.
If you have links to the rotor only, I would really appreciate having that information. Thanks.
-Goat-
help pros need advice on a deal getsum Nitro Off-Road 6 03-05-2008 07:53 PM
