Old 09-17-2012, 03:45 AM   #16
blis's Avatar
The best method I've seen (without a dremel) is using a AUTOMATIC pin hole punch.
It's a heavy spring loaded pin punch and you work around the screw using it to free it.
http://buy1.snapon.com/catalog/item....re&dir=catalog
If that doesn't work, its a dremel, drill or dissassembly.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 09-18-2012, 07:55 AM   #17
Suspended
Trader Rating: 7 (73%+)
Its not just my steering screw, its every screw on the upper steering plate. I'll try drilling it.
chopper82p is offline   Reply With Quote
Old 09-18-2012, 10:30 AM   #18
Fanatiq's Avatar
watch?v=7v5jhJK3tgg&feature=related
( youtube.com....can't post links yet )
This is how I remove my stripped countersunks ( loctite or no loctite )
Fanatiq is offline   Reply With Quote
Old 09-18-2012, 01:35 PM   #19
sschultz's Avatar
Trader Rating: 15 (100%+)
Every circumstance is different, but that be said, a reverse drill bit can be a life saver. A needle nose vise grip, "vise grip" or a quality brand name vise grip makes a big difference. And last but not least, patience...
Shane Schultz
sschultz is offline   Reply With Quote
Old 10-01-2012, 06:09 AM   #20
squillaempusa's Avatar
a drill bit worked great for me when a clutchbell "dome"screw got rounded out. i used a bit slightly smaller than the screw, and every single piece of the screw came out with the shavings. works perfectly.
slash 4x4/ serpent impact/ rs4-2/ thunder tiger ek4/ ofna LX
squillaempusa is offline   Reply With Quote
