Set-up tips for Hot Bodies D8
Hi guys,
I'm using a HB D8 at my local track which is very bump, dusty and has very little grip. I keep struggling with understeer especially when I'm off throttle. What would you suggest? |
Post the setup you are using. Shock Oil, Diffs, Camber and Shock Locations, etc.
losi 30 front 40 rear shock oil with 1.3 pistons, 7 7 2 diffs, 1 front 2 rear camber...
Originally Posted by Kaano97
(Post 11150724)
Hi guys,
I'm using a HB D8 at my local track which is very bump, dusty and has very little grip. I keep struggling with understeer especially when I'm off throttle. What would you suggest? here |
Go to 3K in the Rear Diff. Raise your Rear inner camber link (Start with middle hole since you didnt list). -2 Camber front, -2.5 rear, 32.5/1.3/HB Gray or AE Silver, 37.5/1.3/ HB Blue or AE Silver.
