Old 08-25-2012, 09:52 AM   #1
Default Steering servo, how much torque/speed?
I am in the market for a new steering servo for my RC8. It has the original RTR servo that came with it. Its only 41 oz-in and 0.19 sec. It is super weak, and can barely pull the brakes. I upgraded my steering servo to a Savox 1256tg, but I think that would be overkill for a throttle servo. So the question is, how much torque/speed is enough, without being too much. Trying to save my $$ as much as possible.
mberta2 is offline   Reply With Quote
Old 08-25-2012, 10:35 AM   #2
merdith6's Avatar
Default Ok
about 80 oz of torque and .15 or faster speed.
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 08-25-2012, 11:29 AM   #3
Suspended
Trader Rating: 7 (73%+)
80oz is too low for buggy.
150oz minimum, speed .15 or faster
chopper82p is offline   Reply With Quote
Old 08-25-2012, 11:45 AM   #4
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Sounds like a good throttle servo is what you are after if I read your post right,
You can go with a Futaba 3305. It's pretty cheap and has metal gears (should last a while). It's got right at or close to 200 oz. of torque and the speed is I think .15. I know a number of racers that use that servo for both steering and throttle in a buggy.
There are many to choose from at all different price ranges. If you can go with something around 120 oz of torque or better and .15 on speed or faster you should be good for the throttle
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 08-25-2012, 04:18 PM   #5
Jerm13's Avatar
Trader Rating: 36 (100%+)
+1. Been running a JR 9100S for about 6 years now. Have only replaced 2 cases because the design for the center shaft hoggs out and it gets a twitch when the wheels are off the ground.
150+ oz/in @ .15 seconds or better would be more than enough for any 1/8 buggy.
Serpent Cobra-TE RCR Nova P5 / Serpent SRX8 Werks B7ProKE
AE SC10.2/////AE B5M CE/////AKA/////Serpent America/////Desoto Racing
Spektrum Radios and Servos, Tekin Speedo's and Motors, SMC Batteries
RC Pro Racing VA, Awesome Hobbies(RIP), Debbies RC World VA, Thunder Alley Raceway NC
Jerm13 is offline   Reply With Quote
Old 08-25-2012, 06:31 PM   #6
Trader Rating: 30 (100%+)
I like the Hitec 965MG's on throttle. 0.10 sec and 139 oz/in @ 6v according to their website. Shop around and you should be able to find one for about $60.
Axial Wraith
sdtech58 is offline   Reply With Quote
Old 08-25-2012, 06:34 PM   #7
Zerodefect's Avatar
I run Hitec 7955's on both channels, straight up lipo.
Zerodefect is offline   Reply With Quote
Old 08-25-2012, 06:45 PM   #8
sickpuppy1's Avatar
Trader Rating: 25 (100%+)
The throttle part doesnt need much power, true, but the brake part does, and speed is real important here. You need to be able to get on or off the gas or brakes asap. You have a normal bit of lag in radio transmission and then to the servo and if its slower, it adds up to lost time waiting for stuff to happen. In order to be a smooth, consistent driver, you need to be able to act and not react. Going too cheap on servos only hurts you in the long run. brakes need (IMO) at least 150oz and sub .15 times....preferably sub .13 One of the reasons guys go to high volt servo's now days is due to the speed. Not saying you need those, but its a reason they have gained popularity. Speed for the throttle/brake is more important than speed in the steering actually.
If you cant fix it with a hammer, you have an electrical problem...
TeknoSCT410,Losi 22 2.0 & Eight-B 2.0,Losi LST2 , losi LXT circa 1990, it's a runner!
sickpuppy1 is offline   Reply With Quote
Old 08-25-2012, 09:00 PM   #9
jmaxey51's Avatar
+1, 200oz+ would be best but you can get away with 150oz... IMHO you cant beat the Hobbico CS-170 servo on tower hobbies, it is the Hitec 7955 with a different sticker, exact same servo for less.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 08-25-2012, 09:44 PM   #10
sickpuppy1's Avatar
I used one of the Airtronics 94358 and 94359 for a long time on throttle/brake. 200oz @ .10 And still own them. The only reason I stopped is they are analog and the digital's have better centering.
Old 08-25-2012, 10:15 PM   #11
Sideshow Bob's Avatar
most guys here run the 1256 on steering with the 1258 on throttle/brake. the 1258 is a 170oz/in servo and super fast at 0.08s @ 6V. The 1256 being a 280oz/in servo and 0.15se @ 6 V is great on steering. people use them on throttle as well but at almost half as fast as the 1258 it might not be the best choice.
www.cuziracing.com
Sideshow Bob is offline   Reply With Quote
Old 08-26-2012, 12:00 AM   #12
Suspended
I had the same problem with my JR Z9100S
Old 08-26-2012, 12:42 AM   #13
Rsickles's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to Rsickles
CS-170 is old Hitec 5955, not 7955. See here: Servo Advice Please!!
Rsickles is offline   Reply With Quote
Old 08-26-2012, 01:18 AM   #14
I run stright lipo with savox 1268 on steering and 1267 on throttle.
I did use the 1258 before with nimh both steering and throttle.
it is faster on the paper but not in the track.Witch means that it is to weak for stable steering.
have even used the 1267 on steering and felt the switch to 1268 was faster and more consistent in my hometrack.That are werry hard and bumpy..
Savox SC-1268SG High Torque Steel Gear Digital Servo (High Voltage)-savsc1268sg
List Price $115.99
Map Price $95.99
You save $20.00!
Dimensions(mm): 40.3x20.2x37.2
Weight(g): 62.0
Speed(@4.8V sec/60): .15
Torque(@4.8V oz-in): 160.0
Speed(@6.0V sec/60): .13
Torque(@6.0V oz-in): 208.3
Speed(@7.4V sec/60): .11
Torque(@7.4V oz-in): 347.2
Gear: Unique Steel
Bearing: 2BB
Case: Aluminum
Case: Aluminum
Savox SC-1267SG Super Speed Steel Gear Digital Servo (High Voltage)-savsc1267sg
List Price $115.99
Map Price $95.99
You save $20.00!
Weight(g): 62.0
Speed(@4.8V sec/60): .13
Torque(@4.8V oz-in): 130.0
Speed(@6.0V sec/60): .11
Torque(@6.0V oz-in): 180.5
Speed(@7.4V sec/60): .09
Torque(@7.4V oz-in): 291.0
Gear: Unique Steel
Bearing: 2BB
Case: Aluminum
Sorry for my bad english..
xray808--xb9--sanwa MT4---savox---novarossi--RB--Protek--arrow--buku
xray808-11 is offline   Reply With Quote
Old 08-26-2012, 01:38 AM   #15
I did use the 1258 before with nimh both steering and throttle...
the 1258 should not be used on steering
www.cuziracing.com
best throttle/steering servo 1/8 buggy&truggy ironpeddler Nitro Off-Road 269 12-09-2014 06:19 PM
Spektrum SR3000 Dual Steering Servo? quickshot23 Radio and Electronics 33 11-23-2010 03:33 PM
How much torque in stock Blitz steering servo ? 191185 Electric Off-Road 16 10-12-2010 05:49 PM
How much torque, does one need? RCRat Nitro Off-Road 38 06-25-2009 11:46 AM
