Non RC Tools that have helped you?
Wanted to get an idea of what kind of non rc tools you have found to help you in this hobby. Here is one I have found to pull flywheels off engines. Cheaper than the rc version and works perfect.
http://amceaglenest.com/enstore/inde...d&productId=51
Butter it work great on hinge pins or hub pins your suspension frees up you can take a few seconds off your lap times.
hammer lol
needle to remove the seals from the bearings
chopsticks to remove the mud from the car without scratching everything
scriber to remove the ground from the head of the chassis screws
dog teethbrush to clean electric motors
various brushes to clean the car
adhesive rubber bands used for doors to protect the chassis
....oh yes and nutella in the diffs
-dremel (alltough aren't these for RC now?)
-hammer
-vice grips
-vice
-motorcycle chain breaker
-TAG body spray
-hemostat
-1/4" ratchet, sockets, deepwell sockets
-120/12v 6a float automotive battery charger
-KFC bucket
-hammer
-vice grips
-vice
-TAG body spray
-hemostat
-KFC bucket
I use a car lift so it's easier to work underneath and change suspension setup.An airgun is very handy but a 3mm hex head is hard to find,so I just hammer down those screws.Personally I don't like the butter on the hingepins because of the cholesterol and nutella is bad to diabetes so I just spit on the hingepins.Gotta make sure there's no lettuce or that would mess very badly tire wear!
