INTECH RACING - BR-6 BUGGY!!!
#1681
Nt much action here?
Finished the build and put about a litre through the car yesterday. I'm very impressed with the initial feel of the car. Much better than the build would reflect. I made a few changes from stock based on recommendations in here and our small, bumpy track. So far so good. Let my die hard X-ray mate have a drive and he liked it. Hopefully it is durable and it will be a winner. Where I live the kit is $350 USD!!!!!
#1683
MBX6
#1684
R/C Tech Elite Member
Trader Rating: 123 (100%+)
I carry quite a few spares because that's how I roll. I would recommend the alum servo arm for security. Also the alum shock towers just in case you have a bad crash and the standard carbon towers were to crack or be weakened. The quick change/extended engine mount for convenience. And the lightweight wheel hubs, the lightweight outdrives, the hardened alum diff pins and the lightweight f/r center drive couplers as you have time to further lighten the rotating drive line components. Replacing those parts will give you the original pieces as spares...
You will love the buggy! Good luck and kick some A$$!
#1685
A quick favour to ask people with a new chassis or relatively new one....
You can see my chassis. It is one day old. Just about a litre of use but it appears to be bent! It is con ace. As you can see there are no marks on it and I don't remember having a crash that would cause this.
Can someone please put a straight edge along the bottom of their chassis just to confirm it is flat? I'm pretty sure it is. Is I put I straight edge along mine it has a gap of about 3-4mm in the centre. The body does have marks. Consistent with a flexing crash, like casing a jump. I just don't remember doing it. I cased my agama so hard it flexed the front centre drive shaft out of the centre diff cup and it never bent the chassis. I will be very disappointed if it is bent. Anyone else experience this?
Cheers
Jason
Ps. Sorry for the terrible pic. Was taken with my iPad. First time. I guess it is a rubbish camera!
Cheers
Jason
#1686
Cheers
Jason
Cheers
Jason
The Agama chassis is 4mm thick, the Intech is 3mm. The Intech chassis flexes a lot, which is why we recommend using the extended engine mount to reduce chassis flexing.
But the chassis flexing is what makes the Intech handle so much better on slick and bumpy tracks. But if someone would make a 3.5mm chassis for it, I think that would be better.
#1687
Thanks for the info gene. So I guess it is bent. Hopefully I can straighten it out!
#1688
Take out the engine and radio tray and straighten it.
#1689
Sexy and gorgeous!
That's really cool bro. I mean I have seen a lot of photos like that but I have never seen them that close! Haha.. talking about details. Anyway, my main concern is, how much? I hope not THAT much.
Cheers!
Cheers!
#1690
Just a remark : some 3 mm chassis of other brands I had to review, were pre-bended a bit in the center new, I guessed to counter act
the bending to the other side when in use ..like in the picture here, a new Serpent mkI
could it be the case with the Intech too ?
usually it is bended botttom to the top then
#1691
Interesting! So you can see my intech chassis is bent about the same as your serpent one. I don't think it was from the factory though. Bt I am not certain.
#1692
then it is factory made like this..
yours is peanuts to what I have seen.. the serpent was double or triple of that, brand new
If bend in an incident it would show the other way around, because the weight of the back slams onto the center of the chassis then
Now with the weight of the engine and radiogear the chassis will set flat in use
they do that a lot with 3 mm chassis as they flex more, else with the weight of the gear it would hang belly down which is not so good
so I wouldn't be worried at all..
#1693
#1694
I have never checked a new chassis, but if it is bent the other way then it is fine.
#1695
INTECH Greece- Tsagkarakis Manos wins the 1st
The 4th Round I.M.C. Nitro Cup 1/8 Buggy Championship took place last weekend in Heraklion Crete of Greece. INTECH drivers had good results in the competition with the BR-6! Congratulations!
Tsagkarakis Manos 1st place
Digenakis George 3rd place
