Proper Gear Mesh?
Proper Gear Mesh?
How do you guys properly mesh the clutch bell to the spur gear?
When I started I used a business's card you cut slip between push engine then tighten you should be pretty close now its a feel thing I set by sound and feel. Some say paper but I find it to thin your mesh it over tight. You want a smooth sound nothing gritty or tight.
The way I've been setting my mesh, i cut a piece of paper 1/4" wide and maybe 4" inches long and fold it in half. insert the paper between the gears and push your engine over against your spur gear and tighten your motor mount screws. i normally use notebook paper, I've been using this method for years never had any problems. I seen this method in most manuals for 1/8 scales cars, just dont set the mesh to tight or you will have. The paper gives it proper clearance.
Ok I have tried using paper and also by feel and sound, but the reason I asked is because when I think I have it meshed right, I spin the wheels and a loud noise comes from it although it does not sound like a grinding. Could it just be making a sound because my clutch bell is worn out?
With using paper you can still get it too tight or loose, you have to look what the paper looks like when you take it out, if the paper has been broken its too tight if the crinkles the gears make are soft edged, it's to loose, also is good to listen after meshing it also, get a ear for what sounds right.
