Old 07-14-2012, 12:41 AM   #1
christmaxx's Avatar
Default rc8t center driveline clip.
i am trying to remove the black clip that captures the cross pin in the senter driveline on a associated rc8t championship edition. i did not glue them and still cant get them off. i have tried flat screwdrivers and pliers, to try and pry it off. i can get it to spin in the groove. they just wont come off. is there a trick or seceret to getting them off. Also on the new rc8.2 buggy i notice they now use a o ring to keep the pin in. which i like much better. once i get them off could i just se any large o rimg that fits in the groove or did they change the part that holds onto the pinion gear in the differential to also have a dust boot. i looked the part nuber up and it is defferent since its aluminum on the .2 although it looks like the same part. thanks, chris
christmaxx is offline   Reply With Quote
Old 07-14-2012, 01:10 AM   #2
Use a screw driver to pry the ring off. Stick the blade against the groove and twist it against the ring. If this does not work use a second flat screw driver to spread the 2 ends of the ring then pry it off. I have only had to use 1 and twisted them off. In regards to the Oring on the RC8.2 I have just fitted the rings to mine as I have had a pin come out after the cover tore. I had had one heat to go and lost pin when the oring moved.
Dave
RB OneR V2
RB BXR. Alpha A830 Dragon.OS XZB Speed.
Beta Tyres. www.wprcracing.com
Pro RC Supplies
Flip it is offline   Reply With Quote
