Old 07-09-2012, 12:21 PM   #1
71schaeffer's Avatar
Trader Rating: 8 (90%+)
Arrow Gen III Tray problems
I am having a bit of trouble with my tracy, first of all when i use the throttle i can litteraly see the chassis flex and was wandering if i need t stiffen the mounts, also that long rod keeps hitting the inside of the three way mount when i use the throttle, i will post a picture once i figure out how to to make it a bit clearer
Hobbytown USA Gladstone,MO / StickyKicks RC / Fantom Racing / Clints Creations
71schaeffer is offline   Reply With Quote
Old 07-09-2012, 12:29 PM   #2
cavwrench's Avatar
Trader Rating: 122 (100%+)
Hey pal. I have the gen 3 tray in both my truggy and my buggy. I have had zero problems. It sounds to me like your throttle EPA is set to high. If your EPA is set to high it will pull the throttle further then it needs to and it will flex the chassis. Same if you have the EPA for brakes set to high. Take off your air filter and set your EPA to just where the carb opens all the way with your throttle pulled full open and THAT IS IT. Then push the trigger to set the brake EPA to where the brakes are just lightly applied. NOT PULLING real hard at all and that is it. Try that. It should help you for sure.
Finishline Designz
cavwrench is offline   Reply With Quote
Old 07-09-2012, 12:34 PM   #3
cornerspeed's Avatar
It also sounds like the line marks are not set. There are lines marked on both the tri-horn and throttle servo arm that have to be lined up on the lines on the tray. Those are set for when the throttle is at nuetral position.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 07-09-2012, 05:41 PM   #4
Ok thanks guys, i will try to adjust my EPA i just dont know exactly how to do that, also, talking brake bias how do i do that on the radio? If i dont i can find exactly were to set it on the car can someone help with that? Sorry i am kinda new to Losi
Old 07-09-2012, 06:33 PM   #5
Ok i adjusted my EPA on brake and throttle and it seemed to calm it down, i also moved the throttle servo a bit over to match it up with the lines... it worked, then i cut the tubbing for the rear brake and it seemed to respond a little smoother with less pull. Now i just need to learn to adjust brake bias
Old 07-09-2012, 08:38 PM   #6
vito's Avatar
vito is offline   Reply With Quote
Old 07-10-2012, 02:44 AM   #7
JsK
JsK's Avatar
Originally Posted by vito View Post
Now get down to Jville for round 3 of the OSS series and get that thing dirty
JsK is offline   Reply With Quote
Old 07-10-2012, 08:15 AM   #8
That thing looks to good to be on the track
Old 07-11-2012, 04:15 AM   #9
sickpuppy1's Avatar
Trader Rating: 25 (100%+)
Aint that funny. They look so good, it almost seems a shame to get it dirty. but ya get over pretty quick,huh?
If you cant fix it with a hammer, you have an electrical problem...
TeknoSCT410,Losi 22 2.0 & Eight-B 2.0,Losi LST2 , losi LXT circa 1990, it's a runner!
sickpuppy1 is offline   Reply With Quote
FEAR FARM RC RACEWAY Marcus Falconie Arizona-New Mexico Racing 10056 08-29-2017 10:31 PM
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
Help - Losi 8ight 2.0 T dann1011 Nitro Off-Road 16 03-21-2012 08:49 AM
