Old 07-08-2012, 10:13 AM   #1
Default How to get rid of steering slack?
When adjusting the camber, toe in/out, etc I noticed a good bit of slack or play in the wheels or steering making it seem as if one wheel or the other was no where near even to the other side, even though my measurements are precisely equal on both sides from using calipers. How do I get rid of this annoying slack or play? Or is this something that is there intentionally to help absorb shock or impacts? Car is an lx2...... My first off road.
GregUnd is offline   Reply With Quote
Old 07-08-2012, 02:40 PM   #2
sgp-chris's Avatar
Every kit has a bit of play in the steering. It is normal. Maybe some kits have a little more than others, but they all have some. I don't know if the pros have less play in there steering compared to us mortals though.
I don't know why the slack is there, but you're theory sounds about right. Also it only takes a little bit of play between the servo, steering assembly and toe links to create a fairly big amount of play in the front wheels.
sgp-chris is offline   Reply With Quote
Old 07-08-2012, 03:43 PM   #3
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
Even the most high $$ rides seem to have a good bit of play, I don't see any real ill affects from it though. Not a huge issue for us mortals, IMO.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 07-08-2012, 04:11 PM   #4
GizmoJunkie's Avatar
In my experience i have found that little or no play makes a car feel quite twitchy and not very forgiving to the drivers input.
Funny thing is "a little play" feels like a lot, but "a lot of play" is veeeery excessive and you should notice something worn out and will need to be replaced.
Really tight is twitchy, really loose and the car will feel very "wandery" when driving on a clean flat surface.
FT B4.1, FT SC10, FT B44; Tekin RS/Savox/D3's
HB D8/D8T - Werks/Buku/Savox
Airtronics
GizmoJunkie is offline   Reply With Quote
Old 07-08-2012, 06:30 PM   #5
Cool, thanks guys!
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 10:10 AM
