Right turn, full throttle, servo goes to neutral
Just broke in my lx2, everything is still stock. The problem I'm having is under right turn and 80% plus throttle my steering servo goes to the neutral position. It doesn't do it with the car off the ground, could this be a problem with the differential? If not what could it be?
Originally Posted by GregUnd
(Post 10933660)
http://c456141.r41.cf0.rackcdn.com/i...hrx1600-ib.jpg |
They are brand new batts, but I will for sure replace with your suggestion. Thank you!
Any other possible reasons? Strangely enough, it's only on right turns. |
I will for sure follow your suggestion, thank you.
Any other possible reasons? It's only on right turns and hard throttle, strange. |
+1. you need to get a NiMh RX pack. More voltage for the servos, more time and cheaper over the long run than putting AA's in.
I actually found the problem to be crap servos. Its the vibration causing the action. If I tap on the steering servo I get sparatic movements.
Does anyone have a recommendation to a "best bang for your buck" servo? I'm not racing, just having fun. Although, I'm sure I'll be racing again soon. It's been 8 years since I last messed around with RC cars. |
Savox.
(Post 10934285)
I've been reading a lot about savox. Do I need a digital servo? My radio is a 2.4ghz. Any particular model?
(Post 10934387)
Doesn't need high voltage servos unless running lipo rx battery
