Old 07-02-2012, 01:38 PM   #1
HotbodiesRacer1's Avatar
Default truggy understeer
have good turning radius on the car but the front end pushes in turns like the front end is light. any advice? like lowering ride height or shock setups?
HOTBODIES D8T TRUGGY WERKS B5 , D8 BUGGY WERKS B6 , SPECTRUM, BYRON FUELS, AKA TIRES.
HotbodiesRacer1 is offline   Reply With Quote
Old 07-02-2012, 01:56 PM   #2
nitroexpress's Avatar
You need to list the details of what you are running. Can we assume it is a D8T?
List general details of the type of track. Be sure to list the tires used, and your setup information. Springs, shock oil, diff oil and etc. Try posting in this D8T forum.
Hot Bodies D8 Truggy
nitroexpress is offline   Reply With Quote
Old 07-02-2012, 02:22 PM   #3
yeah its a d8t. ill look into the d8t thread like u said to see what pops up
Old 07-02-2012, 02:53 PM   #4
tc5 man's Avatar
I would say try a little bit of toe out on the front end keep in mind there your steering will be quicker and a little harder to drive.
Make sure the steering saver isnt to loose thats the first thing i would check.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
tc5 man is online now   Reply With Quote
Old 07-02-2012, 04:22 PM   #5
Jerm13's Avatar
Trader Rating: 36 (100%+)
Check what they said on the above posts first. Then if it is still pushing, make sure you dont have too much front brake. If it still pushes, check your rear droop, and front shocks. More rear droop will help transfer weight to the front under braking. Your front shocks are either too stiff and not allowing the weight to transfer or too soft allowing them to bottom out. Then lastly, lengthen your wheel base.
Serpent Cobra-TE RCR Nova P5 / Serpent SRX8 Werks B7ProKE
AE SC10.2/////AE B5M CE/////AKA/////Serpent America/////Desoto Racing
Spektrum Radios and Servos, Tekin Speedo's and Motors, SMC Batteries
RC Pro Racing VA, Awesome Hobbies(RIP), Debbies RC World VA, Thunder Alley Raceway NC
Jerm13 is offline   Reply With Quote
Old 07-03-2012, 08:55 AM   #6
ight man i will check that out thanks. just looking for little changes that i can do without changing the whole setup.
Old 07-03-2012, 10:59 AM   #7
[QUOTE=Jerm13;10929953]Check what they said on the above posts first. Then if it is still pushing, make sure you dont have too much front brake. If it still pushes, check your rear droop, and front shocks. More rear droop will help transfer weight to the front under braking. Your front shocks are either too stiff and not allowing the weight to transfer or too soft allowing them to bottom out. Then lastly, lengthen your wheel base.]
ok will do thanks.
Hot Bodies D8 Truggy Greg B Nitro Off-Road 10028 08-16-2017 05:44 PM
Jammin CRT .5 = 1/12 Truggy Team Kamikaze Nitro Off-Road 2269 07-02-2017 04:32 PM
Team Associated 1/8 scale Truggy Info and Tips Kevin Boyle Nitro Off-Road 4504 01-05-2017 06:52 PM
ThE BoYzz and TheIr ToYZzZ!(nitro buggy/truggy) tony510 Manila Racers 2550 05-02-2016 04:40 AM
