Dual brake linkage
I run this one on my 808 11, works well easy colour identificated of f&r brakes for adjustments.
http://www.amainhobbies.com/product_...ke-Linkage-Set
That one doesnt look to bad though but looks as if you can ony adjust the f&r together.
All kinds of things wrong with the pic in the OP.
-that thing takes up too much space and would limit my throttle travel. Maybe it'll work on cars with pivoting linkages and remote servos, but not a standard setup like my XB9.
-shock orings on the brake pull rods? That' ain't gonna work. Fuel tubing.
-it's going to bind, the pull rods will have to flex instead of pivoting at the servo as they travel through the cam rod eye.
Well I understand it wouldnt be good for your RC but for my application its about perfect.
Only thing I found close is on the Team Associated Factory Team RC8.2
http://www.absolutehobbyz.com/produc...oducts_id=6856
If anyone figurs out what the one in the first picture is Thanks in advance
