Old 06-23-2012, 05:31 PM   #1
Default Troubles starting.
My savage 21 is about 9 years old and probably hasn't been running in about 8 years. Just got myself some new glow plugs, ignitor, and fuel (was told the were all compatable with the truck) but have had no luck in starting it. Quite sure all factory settings are still the same as the were. It doesn't sound at all like it wants to start at all. Any ideas? Thanks.
savage21guy is offline   Reply With Quote
Old 06-23-2012, 05:38 PM   #2
blktransam's Avatar
Trader Rating: 59 (100%+)
Make sure igniter is charged...
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
Old 06-23-2012, 05:45 PM   #3
Yep. It was charged. I've had it running before, and have re-read the manual and some forum posts with similar problems. Other posts seem to be about first start up problems.
Old 06-23-2012, 06:53 PM   #4
Perhaps the engine is flooded from over-priming fuel?
csb510 is offline   Reply With Quote
Old 06-23-2012, 09:21 PM   #5
I think your problem is that the engine is gummed up from leftover fuel from 8 years ago. Can you turn the motor over easily? If you cant, A: it is flooded as csb said, or B: you need to clean all the gunk out of your engine. Either way, you should disassemble your engine to check that everything is in running order, no broken or over worn parts. You could probably find some good videos on Youtube related to gunked up engines, or even on this very forum. Just clean it up and you should be good.
evrydaysk8r is offline   Reply With Quote
Old 06-23-2012, 09:31 PM   #6
Forgot about the possibility of it being a gunked up engine too! Definitely take the engine apart. Check the carb and the crank bearings.
Old 06-23-2012, 09:33 PM   #7
The engine seems to turn over easily. I'll clean it out,like you suggested, and double check the factory settings. Thanks.
Old 06-24-2012, 09:25 AM   #8
polarbear72's Avatar
I'd also replace the fuel lines. They could b gunked up not letting u get fuel. Use the clearer ones so u can c the fuel moving and u will know when to stop priming
Mugen MBX7, Mugen MBX6TRR, Mugen MBX6E, Ninja, Murnan Modified Novarossi Bonito & Werks, Futaba, Tekin
polarbear72 is offline   Reply With Quote
Old 06-24-2012, 10:35 AM   #9
One last thing, if it doesn't start at all after a long time cranking, tilt the truck so that the unburnt fuel in the exhaust dumps out.
Old 06-24-2012, 10:54 AM   #10
merdith6's Avatar
Default Carb
The carb may have some dried up fuel in the inlet. Blow through the fuel line and make sure the fuel can pass through the carb into the engine.
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
New Losi XXX-SCT troubles mmike87 Electric Off-Road 69 12-04-2012 09:33 PM
Engine Troubles PLZ HELP!! Hoggy Nitro On-Road 6 06-27-2005 10:43 PM
Motor Caps & Glitching Troubles....>>> NitroJohnnyD Electric On-Road 23 12-20-2003 11:37 AM
WHY,Why,why....? is Hpi junk? This thing is starting to @#$%!me off! Zuperfastone Electric Off-Road 38 11-29-2002 02:36 PM
