Old 06-22-2012, 11:50 PM   #1
Default Newbie needs your help.. Please!
Hi all,
I have today brought a Kyosha mad Force Kruiser. I had a few issues getting it to run, mostly down to my impatience!, but now have it going. However, it seems to be burning quite a lot of fuel and sometime cut's out after full throttle.
Is there a way to re-set the KE25 motor back to factory setting and start again, as I have changed both the Hi and Low speed needles, and want to be sure that I run the motor in correctly.
Thanks in advance.
Noodles3 is offline   Reply With Quote
Old 06-23-2012, 12:51 AM   #2
partly I am a little afraid of the changes I have made and don't want to mess up the new toy!
Old 06-23-2012, 03:13 AM   #3
have a look at the tuning bible
"the engine tuning bible"
"If you have complete control over the damned thing, you're not going fast enough."
kaan is offline   Reply With Quote
Old 06-23-2012, 03:19 AM   #4
Excellent, thanks Kaan.
Old 06-23-2012, 03:24 AM   #5
oh, and dont forget the break in bible if it is a new engine
"the engine break in bible"
Old 06-23-2012, 02:19 PM   #6
yes, it is a new engine. I didn't do any of these things yesterday! hope I haven't caused any damage..
In terms of the engine temp, I didn't get a device to indicate this so guess I will need to get one of these in order to complete the break-in??
Thanks again
Old 06-23-2012, 02:54 PM   #7
mojoman81's Avatar
Trader Rating: 26 (100%+)
Thanks again
No not really when I ran nitro i used the spit test . Water boils at 212f so i just spit on the head and watched how long it would take to evaporate off . lol , But of course I did buy one . For nitro I always liked the mip or traxxas on board guages they give you a reading over the whole run as well as the peak temp.
G's RC Raceway, Shippensburg, PA
~~~~~ www.gsrc.co ~~~~~~
mojoman81 is offline   Reply With Quote
Old 06-23-2012, 02:55 PM   #8
A cheap infrared thermometer would probably be a good idea.
But you dont absolutely need one.
For many years people have gotten by with the so called "spit test".
Just put a drop of spit on your finger and put the spit on top of the cooling head.
If it doesnt evaporate too quickly, the temp is fine.
So what is too quicly then? well about 3 seconds depending on how much spit there is
Anyway, you will probably be better off with a cheap temp gun
Old 06-23-2012, 06:25 PM   #9
Thanks for your advice folks
I've had a lot more luck today getting the truck started (unlike yesterday!) but now the BIG question is about getting the HSN and LSN set correct
Whilst I now know that I need to run-in the engine, it seems to go ok but I have noticed a lot of fuel spitting form the exhaust and tried to lean out the HSN but this seems to make no difference (on the understanding that I have the car idling and make the change there and then).
Also, based on some experiences of others my truck seems to have strange settings in that the LSN is nearly all the way out and the HSN about 5 turns open from fully closed.
Any ideas???
Thanks in advance.
Old 06-24-2012, 05:00 AM   #10
When the car is idling the high speed needle has almost no effect on things.
If you want to lean it you will have to do so on the low speed needle.
With that being said, since you are still breaking in the engine it is probably a good idea to keep it like this.
Ron from werks has another approach to engine run in, i havent tried it yet, but it looks good and easy to follow
The New Werks B6 .21 Buggy Racing Engine!
its in the first post of this thread :-)
Old 06-24-2012, 11:04 PM   #11
Thanks again Kaan, I will take time to read through and try!
I had it running quite well yesterday and the fuel spitting seemed to be a little less..? Maybe it's down to the engine becoming more run-in..?
All the best,
N
R/C for Kids ! We need your help! RCforKids R/C Racers 4 Christ 7 09-10-2011 05:26 PM
Noob needs help please. Opinions on a Buggy Sk8ordie Nitro Off-Road 6 05-15-2011 12:41 AM
Newbie needs some help. AndyC- Electric Off-Road 10 07-22-2010 04:26 PM
Esc capacitor newbie needs help please scottwhat12 Electric On-Road 8 10-12-2008 07:39 PM
