Old 06-22-2012, 02:20 PM   #1
Default Anyone using a Tiger Drive Starter?
I am a bump box kinda guy, but I found a good deal on a motor that had a pull start that I could not resist. When I got the motor I decided to try the Tiger Drive for the heck of it, which is a pretty slick deal but the darn thing keeps spinning with the motor running. Does anyone else have this same issue?
I called Tiger Drive and they said that it should not do this, but I cannot see how it can be avoided since there is nothing built into it to stop it from spinning. The one-way bearing has to be in correctly since you can only spin the motor in one direction and it is the correct direction. I can also stop and hold the TD with my fingers which also indicates the bearing is in correctly.
This will not be a permanent thing, but any thoughts before I just convert it to bump start?
arrowshooter is offline   Reply With Quote
Old 06-22-2012, 03:15 PM   #2
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Thats why its call a one way bearing these drives are PITA they wear quickly had during my Revos days make sure you dont over power. I perfer a Pull start less issues less gear to carry and its cheaper. Something isnt right pull the back plate off needs to be connected correctly.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 06-22-2012, 03:33 PM   #3
Thanks for the reply. I will take apart and reinstall and see what happens. May end up just grinding the starter nub off the crank, put on a regular back plate and bump it.
Jump Square Arena, Sg Buloh mbskl1963 Malaysian R/C Racers 1709 07-22-2014 08:26 PM
2010 Midwest Series 41st Season (Nitro On-road - 6 races, 4 States) Andy who? Racing Forum 373 01-15-2011 04:37 PM
Pull Start To Roto Start Convrersion Parts dishsoap Nitro Off-Road 8 01-20-2009 12:37 AM
