carbon fiber chassis?
Why arent they used in 1/8 scale buggies/truggies? When thick enough its really strong, is it because of the flex properties or cost or something else?
Originally Posted by railer80
(Post 10885234)
From what I could see, proof-of-concept had been demonstrated rather convincingly, but probably not very lucrative. |
http://www.snrgraphite.com/
I believe they can make you a chassis upon request. They do offer a lot of parts for nitro and electric that crossover to each other. |
Originally Posted by Hpifanboi
(Post 10886912)
I believe they can make you a chassis upon request. They do offer a lot of parts for nitro and electric that crossover to each other. IMHO, Matrix Concepts really had the best formula. How unfortunate that it didn't last. |
Originally Posted by captain america
(Post 10887111)
Everything they produce chassis-wise appears to be for electric. If you look at the MP9 chassis that they offer, the top surface is relatively flat, no milled areas or recesses to clear servos or fuel tank or flywheel. They could probably make a custom chassis to suit your needs, but would likely cost quite a bit more than the already spendy price they're charging.
IMHO, Matrix Comcepts really had the best formula. How unfortunate that it didn't last. |
1/8th nitro buggy chassis are all made of aluminium for there ability to become part of the heatsink for the engine, its durability, easy to machine and strengh in areas like the recessed holes for the engine mounts etc.
The cars are so close to weight limits these days weight's not an issue, the best application in 1/8 is probably E cars, the battery boxes could be molded into the chassis. I know CF is cool looking, what about a alloy/CF laminate/ best of both worlds. Craig |
Originally Posted by curacing2
(Post 10888169)
The cars are so close to weight limits these days weight's not an issue, the best application in 1/8 is probably E cars, the battery boxes could be molded into the chassis. I know CF is cool looking, what about a alloy/CF laminate/ best of both worlds. Craig If anything, it's more of a cost issue than problems related to performance. |
Yep
(Post 10888169)
