Old 06-13-2012, 07:49 PM   #1
Default Regluing tires
One of my tires became partially unglued. Can I just throw some more glue on it and be good to go or do I need to sand down the rim?
Thanks for any help
BlockHed is offline   Reply With Quote
Old 06-13-2012, 07:53 PM   #2
rcduder's Avatar
Thanks for any help
if i were u i would sand down the rim and the tire a bit that way there both clean surfaces so u can have the glue stick like new again (almost like new again)
rcduder is offline   Reply With Quote
Old 06-13-2012, 07:58 PM   #3
Rsickles's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to Rsickles
+1, and don't forget to clean the surface (rubbing alcohol works fine).
New glue on dry glue is a weaker bond than glue on the original surface, so chances are they will just come unglued again without proper prep.
Rsickles is offline   Reply With Quote
Old 06-13-2012, 08:30 PM   #4
Thanks for the input, what grit would u recommend?
Also, do you use tire bands after gluing?
Old 06-13-2012, 09:48 PM   #5
JoePit's Avatar
Trader Rating: 15 (100%+)
I think tire bands are a good investment.
Joe Pitruzzello AKA Joe Pit
Losi 8ight B 3.0|Losi 8ight T 3.0|Losi SCT Nitro|Radiopost|Red Rock Hobbies
www.redrockhobbies.com
Fear Farm Raceway
JoePit is offline   Reply With Quote
Old 06-14-2012, 05:33 AM   #6
Akhor's Avatar
I just use electrical tape wrapped tightly around the tire a couple of times.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 06-14-2012, 11:46 AM   #7
Integra's Avatar
X2 Dont waste Roll after roll of Tape when there's a Cheaper More effective solution. Sure tape works. But why not "Invest" the 5$ in bands and leave the tape out of the equation.
Old 06-14-2012, 12:18 PM   #8
rcduder's Avatar
i just use whatever grit i can find but i noticed that 100-300 grit ive liked the best but nothing over 600 grit i would recommend because that's a little to fine to do this.
tire bands are a great investment i for sure like em better then holding my tires or using tape like i used too
these are cheap and you get 8 of them
http://www3.towerhobbies.com/cgi-bin...?&I=LXXSK6&P=7
Old 06-14-2012, 04:25 PM   #9
Thanks for the link, just ordered them! (they are on back order though...)
Old 06-14-2012, 05:01 PM   #10
Jaz240's Avatar
Trader Rating: 52 (100%+)
Wow $5 for 8 giant rubber bands? pay a little more and get actual tire mounting bands with the tabs on them. VP pro and Panther make them and mine have lasted 6 years so far. Just like everything else in this hobby you can buy cheap 3 times a year or buy good once every 3 years.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 06-14-2012, 05:08 PM   #11
rcduder's Avatar
they are jconcepts though so they are quality ive been using them for awhile and trading off to others to use them
Old 06-14-2012, 07:20 PM   #12
thenova70ss's Avatar
Yep i have a set of Panther bands that are about 8 years old and work GREAT .
CHRIS CREWS
Pro Speed Racing Optima MX1 Buggy http://www.global-hobbies.com.my
Cold Fusion R/C Products Team Driver - www.coldfusionrcproducts.com
Rc Pro ProDucts Team Driver www.rcproproducts.com
Hobby Pro USA Team Driver www.vp-pro-usa.com
thenova70ss is offline   Reply With Quote
Old 06-14-2012, 08:07 PM   #13
rustlererad3's Avatar
never did this till the last time i reglued my tires and what a difference sanding them down makes
I Live to Run and Run to Live...Never Fear, Never Give Up, Never Back Down
WE ARE PENN STATE
rustlererad3 is offline   Reply With Quote
Old 06-15-2012, 09:57 AM   #14
offr0aden's Avatar
If I can offer some advice on re-gluing .. I've taken a couple tires and rims .. placed them in the oven on 350 for 8 to 10 minutes - the glue crystallizes and you can break the bead.. Then pick off the glue from the tires and rim .. scuff / clean and re-glue..
I've done this in between races where I've had great traction but weak foams..
I use Windex to clean the surfaces before gluing..
Hope this helps.
- Team -
"High Speed and Clean"
offr0aden is offline   Reply With Quote
Old 06-15-2012, 10:23 AM   #15
Inner Tubes from dirtbikes work well and are free. I just went into a shop and asked for a used busted inner tube, cut it in strips, bam... I have enough to last me years. Tip came from one of our local Mugen Drivers.
token is offline   Reply With Quote
Solaris Tires E.J. Evans Electric On-Road 504 12-01-2015 02:06 PM
Jaco Rubber Tires TimV Electric On-Road 224 04-19-2008 07:30 PM
Gooey Foam Tires andrewdoherty Electric On-Road 13 11-28-2005 04:08 AM
