Old 06-12-2012, 04:26 PM   #1
STP
Default HB D8T Steering Issues
Just wondering if anyone out there in RC land can give me some ideas on how to get my HB D8T to turn better when under power???
STP is offline   Reply With Quote
Old 06-12-2012, 07:18 PM   #2
mebolson's Avatar
Trader Rating: 39 (100%+)
You will need to post your setup.
E
Support my small time online hobby shop
www.FactoryRCHobbies.com Custom Race Shirts and Pitmats Dealer for: Soar Seiki, T-Pro Racing Tires, Lipo Batteries, MIP Tools, VP-Pro Tools, and some other stuff
mebolson is offline   Reply With Quote
Old 06-12-2012, 07:31 PM   #3
Zerodefect's Avatar
Stiffer rear springs, shorter rear camber link, more camber, full droop, front toe out, inner holes on arms, rear shock in outer tower hole, lower front ride ht.
Thicker front diff fluid. 15/10/5 or 7 AE fluid should do the trick.
Zerodefect is offline   Reply With Quote
Old 06-12-2012, 07:34 PM   #4
merdith6's Avatar
Default Hmm
Can you increase caster a little?
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 06-13-2012, 04:06 AM   #5
ScottyM's Avatar
Trader Rating: 27 (100%+)
Unless we know what set up your running any ideas will be complete shots in the dark..
My suggestion would be to go back to the original out of the box set up..
7,7,4 on diffs, 2 deg Neg camber all around 35-40 on shock oils, set ride height so drive shafts are level front an rear, and set droop to max front and rear, and adjust left to match right, or vise versa, which ever is shortest..
DO these things and I just about bet you'll have more steering then you know what to do with..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 06-13-2012, 12:28 PM   #6
STP
Im running 7,10,3 on the diifs. Stock 400 & 500 oils that came with the kit. negative 2 camber. Ride heights are level.
ONE race old D8T for sale. Very nice! ROSCOE R/C Items: For Sale/Trade 13 04-17-2011 06:17 AM
What Breaks On Hot Bodies D8 and D8T? dmusgrave Nitro Off-Road 8 12-02-2010 09:34 AM
D8T vs. 801XT JSR Nitro Off-Road 7 07-29-2010 07:08 PM
