Old 05-22-2012, 07:46 PM   #1
Default Losi 8b vs. 8t ring + pinion differences?
Humor me for a minute, and if you can, answer my question.
What are the differences between the ring and pinion for an 8b, and that of an 8t?
Reason I ask is I need to rebuild the rear diff on my 8t, and I have a new 8b ring and pinion set that I won't need (sold the 8b).
Icrashalothaha is offline   Reply With Quote
Old 05-22-2012, 07:48 PM   #2
Bigwave's Avatar
Different gear ratio I believe..just count the teeth.
Bigwave is offline   Reply With Quote
Old 05-22-2012, 07:57 PM   #3
So, would it work?
Old 05-22-2012, 09:51 PM   #4
Seattlelife22's Avatar
Trader Rating: 25 (100%+)
It will work as long as you use the buggy ring and pinion but i wouldnt do it...It will the throw your gear ratio off and will make the car handle like poo....
Adam Bennett is the name...
Mugen Seiki, The Beat engines, Futaba, Aka Racing, m2cRacing and Cr graphics
Seattlelife22 is offline   Reply With Quote
Old 05-23-2012, 05:10 AM   #5
I tried it, everything fit the same but I couldn't get it to shim correctly, I'm just going to buy the 8t stuff.
Thanks for the help, however.
