Old 05-17-2012, 03:40 PM   #1
rcboy1's Avatar
Default Odd problem?
Hey all. For starters, I have been in this hobby for a while and know what I'm doing. Although, I am newer to nitro. I am having a weird problem with my car. When I apply throttle on the starter box, then return the trigger back to neutral, the engine takes about 3 seconds to return back to neutral. The servo itself moves back to neutral, but the engine is still spinning faster than it would at neutral. The engine is an nVision 521b. Thanks
-Carter Flotron-
Thanks to the awesome people of my 2015 Sponsors for your support!
|Tekno R/C|Pro-line Racing|HWNA/FalconSEKIDO|
rcboy1 is offline   Reply With Quote
Old 05-17-2012, 04:08 PM   #2
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
you might have a linkage issue it not closing the carb all the way get a rubber band put it on the carb leg run it to the high needle. Make sure you put the linkage on the carb before securing the rubber band play with the tension you dont want a lot just enough so the rubber pulls everything shut this is also a safety and motor saver.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 05-17-2012, 04:18 PM   #3
rcboy1's Avatar
I thought that might be the problem also, but seems like no luck. Could it be an air leak? I have noticed some fuel dripping down from where the header meets the pipe. Also, my header had a large dent in it, but is not pierced.
-Carter Flotron-
Old 05-17-2012, 05:28 PM   #4
Take some motor spray and while running spray it around areas that could be leaking if the motor cuts off or changes tune you have a leak in that area.
Hot Bodies, Proline, Byrons Fuels, Hitec, Amain.com, Protek, Samurai, Avid Bearings, Dialed, Venom Rc, Advantage racing products.
PUDDIN is offline   Reply With Quote
Old 05-17-2012, 07:06 PM   #5
robbieg's Avatar
Trader Rating: 26 (100%+)
richen the lsn.
robbieg is offline   Reply With Quote
Old 05-17-2012, 07:09 PM   #6
bigjayjay1's Avatar
OK motor details
Is the motor new
If used how many gallons are you the original owner
What's your setting for the high and low needles Flush, two turns in from flush etc?
Take the filter off and Carb restrictor out of the Carb the gap between the slide and body should be close to the thickness of a credit card.
What fuel
What plug
Old 05-17-2012, 07:12 PM   #7
merdith6's Avatar
Default Yep
You either have the idle sppeed too high and the bottom a bit fat, or the bottom too lean and or the top a bit lean.
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 05-17-2012, 07:22 PM   #8
Frank L's Avatar
Trader Rating: 148 (100%+)
Richen the top a little and see if it helps. If not then>>
Lean out the bottom to where it holds and drop the idle down.
Old 05-17-2012, 08:59 PM   #9
rcboy1's Avatar
OK motor details
Is the motor new
What fuel
What plug
not exactly, It's been ran through about 8 tanks not including break in.
Will check tomorrow for needle settings.
I have the carb set right, it's about .7 mm.
thanks, will try it out tomorrow.
-Carter Flotron-
Old 05-17-2012, 09:18 PM   #10
RCmayor's Avatar
Send a message via Yahoo to RCmayor
The idle gap could still be too big at .7 Measuring idle gap doesn't work, it just gets it close.
RCmayor is offline   Reply With Quote
Old 05-17-2012, 11:04 PM   #11
Rock333's Avatar
Trader Rating: 51 (100%+)
It could be a tuning problem like others a have said but i would check to make sure that there is no binding in the carb. Just because the servo returns back to neutral does not mean that the throttle is getting closed. If there is binding in the throw it will cause the issue you have as well.
PM for faster response on items for sale.
Futaba
Novarossi
Proline
J Concepts
Rock333 is offline   Reply With Quote
Odd Novak GTX problem exint2 Electric On-Road 8 11-23-2006 08:20 AM
Strange steering problem bozla Electric On-Road 17 09-02-2006 06:45 PM
