Old 05-15-2012, 02:55 AM   #1
Default setup xray xb808 shock rebound
Hello,
I have xray xb808 2011 shock absorbers.
I find difficult to set them up with the correct rebound.
If I set them up with 25% rebound the buggy bottoms out too much (the track that I am racing has not big jumps but there are a lot of bumps).
If I set them up with 75% -100%, the buggy is bouncy...
I use the xray foams behind the bladder and the new progressive springs.
Do you have any suggestions?
mike80 is offline   Reply With Quote
Old 05-15-2012, 03:25 AM   #2
Sideshow Bob's Avatar
bottoming out is sortoff an xray 808 thing..their shocks werent that great and the limited droop makes them bottom out easier than say the mugens...that being said, although my 808 did slap hard over the odd big jump or two..it never did it all the time...perhaps your shock oils are a bit thin? i used to run blue grey front spring and stock silver rear coupled with about 35 in the rear with 40 up front...that worked on most tracks. If you use the stock larger hole shock pistons (instead of 10 or 8 holes option ones) try going a bit thicker in shock oil. a smaller hole piston will give you more "pack" as the shock compresses so that may be why my 808 did not bottom out AS much..although it still did on some areas.
www.cuziracing.com
Sideshow Bob is offline   Reply With Quote
Old 05-15-2012, 04:14 AM   #3
Zerodefect's Avatar
Try 1.2x8 (F) and 1.1x10 (R) pistons and 40wt AE oil. 1.3x8 in the rear is normal, 1.2 or 1.1 pistons will pack better.
Use the bottom row of holes in the tower and inside holes on the arms to increase droop. Run full droop.
Or better yet, upgrade to Xb9 shocks, towers, arms, rear V2 carriers.
Zerodefect is offline   Reply With Quote
Old 05-15-2012, 05:22 AM   #4
I run 1.3 x 8 holes rear with 700cps oil and still slaps very easily.
New XRAY 808 Philipm Nitro Off-Road 12372 12-08-2015 06:43 AM
