Old 05-13-2012, 03:36 AM   #1
spykee's Avatar
Default how do i stop the front wheel lifting up in a turn?
i have a problem where my off road car's front inward wheel lifts up in a hi speed turn, usually flipping it over. e.g. if i turn left a just 3/4 throttle it will lift up the front left wheel and balloon it. is this down to the wheel ballooning or do i need to adjust the camber and tracking.
thanks for help
spykee is offline   Reply With Quote
Old 05-13-2012, 03:46 AM   #2
Zerodefect's Avatar
-Less front droop
-stiffer springs
-stiffer sway bar
Are you running on pavement? Offroad car + pavement = traction rolls.
Zerodefect is offline   Reply With Quote
Old 05-13-2012, 04:03 AM   #3
PAGIE #536's Avatar
Post
yeah go up in sway bar or in 1mm increments from the ball joint if you find you lose too much steering going up a bar, then adjust in 1mm increments until you are happy.
-Simon Page-
AKA Australia/Ryper Hobbies
https://www.flickr.com/photos/simonpagephotography/
www.facebook.com/SimonPagePhotography
PAGIE #536 is offline   Reply With Quote
Old 05-13-2012, 05:00 AM   #4
l3asher's Avatar
3/4 throttle = slow down maybe.
l3asher is offline   Reply With Quote
Old 05-13-2012, 05:09 AM   #5
BMenard17's Avatar
Trader Rating: 88 (99%+)
if this is his only issue then fix it and go faster.. maybe
Tekno R/C-Sweep racing tires-Rc addiction products
Lead finger racing-Hobbico-OS engines-Futaba-Odonnell
BMenard17 is offline   Reply With Quote
Old 05-13-2012, 05:31 AM   #6
psr
psr's Avatar
is it traction rolling mate you also said balloning
so for traction rolling id lower rear roll centre
also try going up in front diff oils and centre maybee
psr is offline   Reply With Quote
Old 05-13-2012, 06:37 AM   #7
spykee's Avatar
there is no sway bar. but i will decrease the droop and see if that has any affect, also could camber be part of this?
what front diff oil do you recommend for racing (getting into it)
Old 05-13-2012, 11:04 AM   #8
PAGIE #536's Avatar
what car u running ? i would bet that is the reason you are having that issue. no camber wouldn't be the cause.
-Simon Page-
Old 05-13-2012, 12:27 PM   #9
Trader Rating: 25 (100%+)
U should deffinently have sway bars on... If can't get swaybars, shorter and lower inner camber links will prevent body roll.
KainK is offline   Reply With Quote
Old 05-13-2012, 12:28 PM   #10
spykee's Avatar
i am running a Carson (Tamiya) specter
goo.gl/gUIrT <link to the product page
Old 05-13-2012, 12:30 PM   #11
spykee's Avatar
looking for a sway bar now, will have to look on ebay.de tho so min price is 20 pounds
Old 05-13-2012, 12:35 PM   #12
RCmayor's Avatar
Send a message via Yahoo to RCmayor
Get a rear bar first, if it is lifting on power that means the weight is transfered to the rear outside tire. This makes the opposite front lift.
RCmayor is offline   Reply With Quote
Old 05-13-2012, 12:37 PM   #13
Trader Rating: 18 (100%+)
You can also try stiffer rear springs and sway bar to keep the weight on the front.
David Osborne,
Nemoracing usa
Gofast hobbies,West Virginia hobbies
Amain Hobbies
Fioroni usa
xxxntwv is offline   Reply With Quote
Old 05-13-2012, 06:11 PM   #14
A heavier weight diff fluid in the front might help too, if you have a front diff that is
Bo0m UR DEAD is offline   Reply With Quote
General offroad setup Lots of great info! slim jim Electric Off-Road 20 07-04-2017 10:26 AM
New Team CRC Gen-XL johnnywhopper Electric On-Road 1259 10-24-2013 10:33 AM
