Jammin x1 CRT center diff
Yeah but u need the shorter buggy mount ! The stick one raises it up so it doesn't poke thru the chassis !! If u do change it u have to change the ring and pinion too or gearing won't be right !!
I was thinking about swapping mine too, just didnt want to have to buy the ring/pinion for the front and back too. Also mine is brushless converted so that might mean i would have to change or modify my motor mount.
http://www.nitrohouse.com/Center-Dif...95_p_7825.html
http://www.nitrohouse.com/Center-Dif...-1_p_8017.html
(2ea.)http://www.nitrohouse.com/BRAKE-CAM_p_8052.html
Above, are the parts that you will need to lower the center diff.
Look through the parts lists for the Ofna DM-1e Spec and the
Ofna Nexxt-E to get the parts that you will need for the center
spool set up. You may end up having to use the Ofna DM-1e Spec
motor mount too. Good luck.
