Old 05-11-2012, 03:19 PM   #1
Default Throttle servo failure
A quick overview.
I was breaking in my Thunder Tiger 1:10 Tomahawk ST. After maybe 30 minutes, during the 3rd tank, my throttle failed to respond (luckily, I happened to be idle at the time). My steering was still functional though.
I 'binded' the transmitter and receiver, replaced all the batteries, did everything I could to configure the transmitter and receiver correctly (as per the instructions), but still the throttle servo was non responsive. In an effort to rule out the transmitter's throttle control as the source of the problem, I swapped the steering and throttle servo inputs (into the receiver), and as expected, I could steer with the throttle, but steering gave no response to the throttle. In my mind, this rules out the transmitter as the source of the issue, as well as the receiver. Also, I of course checked for obstructions and I stripped down the servo to the bare box and cog; still no response.
Anyway, "long story short", I figured that my throttle servo (Ace R/C S1903) was bust. Its very subtle and very broken responses to the transmitter is also a pretty good indication. I have ordered an identical new servo which will take weeks to ship, so I'm wondering if there's any better options for servos which would be compatible with the Thunder Tiger 1:10 Tomahawk ST.
Can anyone help me out with any ideas about how to determine a suitable alternative servo? Perhaps a more robust and more easily available one too.
Thank you
edit: I have posted a reply bigjayjay1, but it needs to be approved by a mod to be shown for some reason. I basically asked whether there's any obvious issues with installing/running the Spektrum Digital High Torque Sport Servo (can't post link, not enough posts). Savox is obviously a very high quality brand, but the Spektrum has a great price and good reviews from what I hear.
Last edited by r.hackett; 05-11-2012 at 06:10 PM. Reason: exserlunt grammer und speling
r.hackett is offline   Reply With Quote
Old 05-11-2012, 03:30 PM   #2
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Yes check out Savox servos they last with good quality but EPA setting and linkage setup is KEY if done wrong any good servo will take a dump over time. Im pretty sure your servo is standard "Size".
You need a basic servo anything around the 200oz will be fine
http://www.amainhobbies.com/advanced...s=savox+servos
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 05-11-2012, 03:52 PM   #3
Thanks bigjayjay1. I've checked out Savok servos, but I also came across the SPMSS6000 "Spektrum Digital High Torque Sport Servo" (sorry, can't post link, not enough posts). Do you think there may be any problems installing/using this servo in my truggy?
Losi 8 1.0 throttle servo damage? tmaxx26power Nitro Off-Road 12 09-11-2010 06:56 PM
Planning on replacing throttle servo. Help? helgso Nitro Off-Road 19 12-17-2009 01:42 PM
What Throttle servo should i buy? compaq888 Nitro On-Road 81 09-04-2004 09:20 PM
