Old 05-11-2012, 08:37 AM   #1
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Default Fuel Gun which Brand - No Leaking
I've been noticing some fuel guns do leak personally don't own was looking to buy one. I want one that's going to last and NOT leak any suggestions.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 05-11-2012, 09:10 AM   #2
Frank L's Avatar
Trader Rating: 148 (100%+)
The nova gun is the nicest I have ever used but the tubes inside cracked and there are no parts replacement so my $100 Gun is useless.
I have been using a protek gun since I swapped it at a raffle and it works good. Hasn't leaked yet.
Old 05-11-2012, 11:05 AM   #3
Frank do you have any idea what caused the cracking in your Nova Rossi fuel gun?
Team Associated, JConcepts, M2C Racing, Big Pimpin Paints
Chris Reilly is offline   Reply With Quote
Old 05-11-2012, 11:16 AM   #4
LOW ET's Avatar
Trader Rating: 95 (100%+)
i just picked up a vp pro gen 2 fuel gun.
question for those that use a fuel gun, do you use a gun with a truggy? does your gun reach the tank through the top of the truggy body? did you just keep making the hole in the top of the body bigger until the gun reaches the tank?
LOW ET is offline   Reply With Quote
Old 05-11-2012, 11:27 AM   #5
Frank L's Avatar
I guess it could have been dropped but I would think it would withstand that. 1 day I pulled it out to use it and it was leaking all over the place. That's when I discovered the tubes were cracked so it sits in the cabinet now
Old 05-11-2012, 12:11 PM   #6
rider313's Avatar
Trader Rating: 94 (100%+)
This has to be the sweetest one I have seen.
Originally Posted by 22Racer View Post
The new Rw mods fuel gun, sorry I am not making them. Loved my Rb gun but will like it better seeing the fuel in it now.
Rex
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 05-11-2012, 01:53 PM   #7
Jaz240's Avatar
Trader Rating: 52 (100%+)
If you take apart the gun you buy and stretch the spring so it has more tension it stops the leaking. Also WD-40 on the trigger and moving part helps it close and seal better. I use a $30 VP fuel gun and it works great with no leaking.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 05-11-2012, 03:04 PM   #8
bigjayjay1's Avatar
Wow thats a GUN thanks guys i pitted for a buddy his gunwas fast but it was leaking wasnt sure if that was common. I seems that protek, losi maybe VP use the same manufacture just rebadged they look the same.
Old 05-11-2012, 03:10 PM   #9
Rsickles's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to Rsickles
About the leaking... you have to keep the gun angled downward or it'll leak out the back. You can't point the nozzle upwards... that's why some have stands to keep the angle downward.
Durango, Protek, VP, Jammin, RB are all clones of one another. The only difference is 150cc vs 200cc reservoirs.
And if you don't like spending $30 on a gun... Save $24 and deal with the headache of HK shipping: http://www.hobbyking.com/hobbyking/s...dProduct=14453
Rsickles is offline   Reply With Quote
Old 05-11-2012, 03:27 PM   #10
bigjayjay1's Avatar
WOW Thats Cheap
Old 05-11-2012, 03:58 PM   #11
nitroexpress's Avatar
Several comments on the HobbyKing page for this item report slight leakage with the nozzle down. Is this common for most guns on the market?
nitroexpress is offline   Reply With Quote
Old 05-11-2012, 04:14 PM   #12
trimble's Avatar
Every gun I have ever seen or used has leaked no matter the brand. I use the $100 Novarossi Fuel gun and it leaks also. The more I use it throughout the day the less it will leak, I guess the o rings swell from the fuel. Me and my buddies usually just wait until the pit lap and use a fuel bottle to fill the gun, and then use the gun to fuel the car. This way the fuel isn't sitting in the gun any loner than a minute no matter what. If you simply fill the gun and let it sit more than likely it will be empty when you need it.
Mugen MBX7: Maxy's Cinco 5BT Tuned w/9901
Futaba 4pks
Savox HV's
Boca Bearings-VP Pro USA
trimble is offline   Reply With Quote
Old 05-11-2012, 04:27 PM   #13
bigjayjay1's Avatar
Hum maybe your need to stretch the spring as Jazz stated someone should make a bullet proof gun at a low cost.
Old 05-11-2012, 05:27 PM   #14
I have one like the HobbyKing gun. Identical, save for the Caster badging(door prize). It leaks for sure regardless of what angle you hold it at.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 05-11-2012, 07:52 PM   #15
I use the Losi gun on my RC8T. I have the Proline Bulldog body on my truggy. Yes, I just keep making the hole bigger until the gun reaches the tank.
I've never seen a fuel gun that doesn't leak to be honest. I don't use my fuel gun because i'm the one behind the remote not in pit lane, but I have asked my dad who fuels me if my gun leaks and he said, "it sure does lol I just fill it up the lap before you come in and let it drip pointing down".
Tekno Rc~Dialed-Rc~James Racing Tires~Tekin~DE Racing
Mark K is offline   Reply With Quote
