Old 05-09-2012, 08:12 AM   #1
Default jammin x1crt and x2crt parts compatibility.
Ive noticed that when looking at parts for my x1crt than alot of the time it says it will also fit the x2crt, and sometimes the nexx8, Just wondering what the main differences are between the x1 and x2? Maybe some pics?
Thanks in advance.
Lukescb7 is offline   Reply With Quote
Old 05-09-2012, 08:20 AM   #2
Thanks in advance.
as i just did a castle conversion for cr1, the main plate{chassis} is different.
and as most know the shocks on the x2 are 16mm the x1 are 13mm.
thats all i know.
this would be good informational to know what is and isnt compatibile.
jay71 is offline   Reply With Quote
Old 05-09-2012, 08:23 AM   #3
thats all i know.
On amain when you look at parts alo of them say they are compatible. One thing i cant find is what bodies fit without hacking? Wonder if the x2 bodys fit. Do you know what is different about the chassis?
Old 05-09-2012, 09:13 AM   #4
The suspension components are all the same. But there were different springs for the X2. The chassis is set up with the weight bias different and the chassis shape is a bit narrower and lighter. The center diff mount and brake set up are a bit different. X1 bodies fit X2 truggies. Engine is back 5mm i think. Tanks are different, X2 is longer and has quik change posts for tank w/ body clips. I think the diff gearing changed too.
Hope that helps
T'sDad is offline   Reply With Quote
Old 05-09-2012, 09:23 AM   #5
nitrotrippertje's Avatar
As far as i understand the engine is placed more to the middle and front on the x2 so the centerdiff is on a other location also.
The x2 uses cvd,s allround 16mm bigbore shocks intergrated tabs on the tank for the fuellines different spurr,pinion and gear on the front and back diffs called heliconical or something like that.
And some other different things but most parts are compatible
JAMMIN X2 CRT lightweight WERKS B7 pro/2013 JAMMIN X2 CRT lightweight WERKS B5/2057
JAMMIN X2 CRT Picco P7R EDO mod/JP-3 HB Lightning pro-evo PICCO P3R picco 2046 savage twinzilla/FLM/flux 2350
nitrotrippertje is offline   Reply With Quote
Old 05-09-2012, 09:34 AM   #6
As for pics:
And a butt shot hehe
Old 05-09-2012, 10:03 AM   #7
Thanks alot, is the second body made specifically for the x2?
Old 05-09-2012, 02:44 PM   #8
It is a mugen mbx6t bulldog body check the x2 CRT topic for other options.
Old 05-09-2012, 03:24 PM   #9
I cant seem to find the thread with the search function, have a link?
Old 05-09-2012, 07:37 PM   #10
JAMMIN X2 CRT!!!!
I have the x1, Ive read the d8t bulldog body also fits with some slight mods. Aka 0 offset rims should also fit.
The x1 and x2 do share a lot of parts as does the nexx8t. The nexx is the newest version of the jammin, they dropped the name because "Jammin" Jay Halsey no longer works with Ofna.
As the others mentioned some parts don't fit without some work. The spur gear on the x1 has 62T, the x2 has 48T(I believe), the center diffs are set up differently so I'm not sure if it's just a direct swap. The x2 plastics are supposedly better than the x1 also. I believe the arms all fit both, but due to the different position of the diffs, the shafts don't fit.... All though again, I'm not positive
I'm still learning also, I'll be checking back to this thread
BlockHed is offline   Reply With Quote
Old 05-10-2012, 05:57 AM   #11
Thanks alot for the link, Ill try to keep this going so we have more options. I know the wing mount is the same on numerous ofna/jammins. Forgot to mention mine is also electric converted.
Old 02-08-2017, 03:15 PM   #12
Default Ofna Jammin X1CRT and X2CRT
I would like to know, Im converting my Jammin X1CRT TO BRUSHLESS AND I LOOKING FOR A MOTOR MOUNT, THE MOTOR MOUNT OF A X2CRT WOULD FIT INTO MY X1CRT?
racso97 is offline   Reply With Quote
Old 02-09-2017, 04:32 AM   #13
RC Willpower ofn 41125 supposidly fits x1crt x2crt and x3e sabre. I have nexx8T and have been wanting to convert it also. been thinking about fabricateing a M/M out of alum. channel stock.
bob.less is offline   Reply With Quote
Old 02-09-2017, 05:04 PM   #14
Have you tried NitroHouse.com they still have some Jammin parts left. I had an x1 and x2 and I still have the HN X3 sabre. I would to sell it cheap if anybody is interested pm Michael
stoney452 is offline   Reply With Quote
