Old 04-30-2012, 05:46 PM   #1
JoePit's Avatar
Trader Rating: 15 (100%+)
Default Snapped Allen Head in Set Screw
Am I up the creek or is this salvageable?
Joe Pitruzzello AKA Joe Pit
Losi 8ight B 3.0|Losi 8ight T 3.0|Losi SCT Nitro|Radiopost|Red Rock Hobbies
www.redrockhobbies.com
Fear Farm Raceway
JoePit is offline   Reply With Quote
Old 04-30-2012, 05:49 PM   #2
offroad dude's Avatar
Trader Rating: 25 (100%+)
If the hole goes all the way through, you can put a small drill bit on it from the opposite side. That always work for me.
offroad dude is offline   Reply With Quote
Old 04-30-2012, 05:51 PM   #3
JoePit's Avatar
Doesn't go all the way through. This is the worst possible spot for this to happen and I think it's going to cost me 90 bux. The channel it's sitting in is the problem. I'll try anything so I'm all ears
Fear Farm Raceway
Old 04-30-2012, 06:04 PM   #4
prowlag's Avatar
I had the same thing happen to me last night. My trusty (well I thought they were) proline hex wrench snapped its head off whist I was trying to remove the set screw from the sway bar ball. Anyone have any ideas on how to get it out???
LRD - Werks Race Blend Fuel | AKA - Ryper Hobbies
prowlag is offline   Reply With Quote
Old 04-30-2012, 06:04 PM   #5
BMenard17's Avatar
Trader Rating: 88 (99%+)
Id try an easy out first, you could always tap it out with the next size up grub screw
Tekno R/C-Sweep racing tires-Rc addiction products
Lead finger racing-Hobbico-OS engines-Futaba-Odonnell
BMenard17 is offline   Reply With Quote
Old 04-30-2012, 06:06 PM   #6
JoePit's Avatar
Easy out for something that small? That's a 1/16 Allen right there not sure easy outs go down that small.
Fear Farm Raceway
Old 04-30-2012, 06:14 PM   #7
BMenard17's Avatar
try northern tool and equipment
Old 04-30-2012, 06:18 PM   #8
LOW ET's Avatar
Trader Rating: 95 (100%+)
left hand drill bit
LOW ET is online now   Reply With Quote
Old 04-30-2012, 06:20 PM   #9
BMenard17's Avatar
Hopefully you can buy just one bit cause you could spend more on the bit set than the hub
Old 04-30-2012, 06:22 PM   #10
JoePit's Avatar
You think a 5/64 easy out is to big? That's the smallest ACE carries around here or I'll have to order a kit from EBAY.
Fear Farm Raceway
Old 04-30-2012, 06:28 PM   #11
BMenard17's Avatar
its just s hair bigger.. might be worth a shot if had cheap or a friend has one you can try.
Old 04-30-2012, 06:30 PM   #12
TeamSkunkwerks's Avatar
Trader Rating: 91 (100%+)
Exclamation
Have a set of these myself. Might work for you too!!
http://www.harborfreight.com/12-piec...set-40349.html
Also might try using JB Weld or epoxy & actually bonding the wrench (use a cheap Allen if you have one) to the screw. Let it sit overnight to bond. Then slowly try to back the screw out. Could also use heat to try to break the bond.
I am highly paid by my sponsors not to mention their names. They give me stuff so I will go away.
An American is someone who may disapprove of everything you say, but will defend to the death your right to say it.
TeamSkunkwerks is offline   Reply With Quote
Old 04-30-2012, 06:34 PM   #13
JoePit's Avatar
On my way to Harbor Freight right now. Thanx for all the help folks
Fear Farm Raceway
Old 04-30-2012, 06:37 PM   #14
BMenard17's Avatar
let us know if you get it out and what worked
Old 04-30-2012, 06:49 PM   #15
RCmayor's Avatar
Send a message via Yahoo to RCmayor
I have had good luck with a really strong magnet. Gotta tap on it a little and give it time but it will usually dislodge it and pull it out. Think Neodymium strong.
RCmayor is offline   Reply With Quote
Ask Aaron Waldron Aaron Waldron Nitro Off-Road 4285 11-03-2011 12:23 PM
Do any online stores carry hudy lathe parts? Cardboard Electric On-Road 8 10-03-2004 07:22 PM
