Snapped Allen Head in Set Screw >
Old 04-30-2012, 07:01 PM
  #16
afr0sch's Avatar
Trader Rating: 95 (100%+)
Default dont use too much threadlock
Perfect example of why you shouldn't put a bunch of threadlock on small grub screws. I bought a used roller recently and I had to drill out almost every 3mm grub since the previous owner seized them all up with too much threadlock. They would strip when you tried to remove them. I could drill them all the way through then remove the excess with a screw extractor. Luckily I could just re-tap the hole with a 3mm tap if the threads got buggered.
afr0sch is offline
Old 04-30-2012, 07:41 PM
  #17
JoePit's Avatar
Trader Rating: 15 (100%+)
Just figured I would report back. I took the carrier and threw it as FAR as I can into the desert. Then I took the Harbor Freight extractor set and did the same thing. I feel much better now.
By the way the Allen broke when I was trying to put it back together. Everything came apart just fine, but the set screw simply would not screw in properly. This is not a case where I used to much Loctite. Guess Losi will get me for another $90.
JoePit is offline
Old 04-30-2012, 09:57 PM
  #18
Rsickles's Avatar
Trader Rating: 21 (100%+)
Were you just trying to get the allen out or the grub screw too?
Since the hub is aluminum you could try tack welding the whole grub screw onto a steel dowel/rod, and twist it back out.
Of course the easiest method is if you know a machinist... give it to them. Case of beer is cheaper than new carriers.
Rsickles is offline
Old 04-30-2012, 10:15 PM
  #19
JoePit's Avatar
I tried both. After all the drilling the allen and grub became one. I still have the carrier so I might bring it to someone tomorrow. I called a close friend that's a machinist, and his message stated he was out of the country till next week The spindles are on back order to boot. What upsets me most is that I only have 2 rides on this set.
JoePit is offline
Old 05-01-2012, 02:57 PM
  #20
BMenard17's Avatar
Trader Rating: 88 (99%+)
Sorry we couldnt help
BMenard17 is offline
Old 05-01-2012, 03:29 PM
  #21
Jaz240's Avatar
Trader Rating: 52 (100%+)
Joe, just drill it out of there and drill the hole out also and then re-tap it for a 4mm set screw. You need a drill press
Jaz240 is offline
Old 05-01-2012, 03:35 PM
  #22
JoePit's Avatar
I ordered another set in the meantime till my friend with a press gets back from his vacation. I would be willing to pay someone local to fix this for me if anyones interested.
Thanx for all the help
JoePit is offline
Old 05-01-2012, 04:04 PM
  #23
RCmayor's Avatar
I'm tellen ya, small strong magnet always works for me. It's not like that piece is glued in there. No need to drill anything. I use one of those little magnets on a retractable rod for when you drop something. You just need to find one with a small tip since it is a little recessed.
RCmayor is offline
Old 05-01-2012, 05:06 PM
  #24
Work it around with the tip of a exacto knife and then use a strong magnet.. Always works for me.
nothin special is offline
Old 05-01-2012, 06:14 PM
  #25
RCmayor's Avatar
Yep, sometimes you have to work it loose a little cause a hex that breaks usually gets stuck at the engaged position. That's why in my original post I mentioned tapping on the broken piece a little. It loosens it from a stuck position a little. I don't know how many tips over the years have broken off in pinion set screws. Several at least.
RCmayor is offline
