Old 04-28-2012, 01:55 PM   #1
hayabusafmw's Avatar
Default D8t .28 axial doesn't fit on mount???
how to fit .28 into the stock d8t mounts???
www.rcprofile.com
hayabusafmw is offline   Reply With Quote
Old 04-28-2012, 02:00 PM   #2
LOW ET's Avatar
Trader Rating: 95 (100%+)
most likely you will have to grind/cut away the part that is hitting on the engine. i had to do this for a picco engine.
LOW ET is offline   Reply With Quote
Old 04-28-2012, 02:00 PM   #3
Sein's Avatar
You either have to take the pull-starter/roto-starter off and put a closed back plate on; or get a different engine mount for pull-start type engines.
Ronnie Senters/Glory2God Racing
D8T-Alpha A352/D812-Alpha A852
Team Hotbodies Hawaii
Sein is offline   Reply With Quote
Old 04-28-2012, 02:02 PM   #4
LOW ET's Avatar
i didn't even think of a pull start engine.
what is stopping the engine from fitting the mounts?
Old 04-28-2012, 02:05 PM   #5
pull start... but even tho it doesn't seem to be such a problem at all
does the D8T compared to losi rtr roller similar?
www.rcprofile.com
Old 04-28-2012, 02:46 PM   #6
http://nitrocarnage.com/ncforums/vie...php?f=81&t=237
this is the exact engine i have !
www.rcprofile.com
Old 04-28-2012, 05:20 PM   #7
Trader Rating: 39 (100%+)
You need to convert it to bump start or dremel the hell out of the engine mount and chassis.
BrakeTurnAccelerate is offline   Reply With Quote
Old 04-28-2012, 07:59 PM   #8
I found a quick easy solution
I have a d8s
took it's mount!
just need to order a new one for the d8s
problem solved!
www.rcprofile.com
