Old 04-21-2012, 08:06 PM   #1
drstrangelove's Avatar
Default Hudy off-road starter box
Hi Guys,
Anyone running 2x 14.8V 20C Lipo on Hudy starter box? or you guys run only 1?
The 2x 7.4V kind of lame
Accepting sponsors who need to test their products durability :)
drstrangelove is offline   Reply With Quote
Old 04-21-2012, 08:21 PM   #2
2x14.8's ?? You mean one right? Yes one 4 cell Lipo works great. I use this one- Plenty of juice and super light in the Hudy box-
http://www.amainhobbies.com/product_...Ah-Starter-Box
You use two 4 cells and your box will be dead in about 10 seconds
skye b. is offline   Reply With Quote
Old 04-21-2012, 08:38 PM   #3
Hmm, so of I run just one that mean I must chane the cable to single lipo?
Old 04-21-2012, 08:58 PM   #4
305M3's Avatar
Trader Rating: 40 (100%+)
That's a good question and as a nuclear engineer I should have an answer - but i don't. hahaha.
My initial thought is yes, make it a single connector. Only because they share a common ground and the power wire splits also. But now I'm tempted to try it out.
actually, if you could hook up one of u're 7.2 v's and see if it cranks over, that may give us the answer.
GL
305M3 is offline   Reply With Quote
Old 04-21-2012, 10:48 PM   #5
Jaz240's Avatar
Trader Rating: 52 (100%+)
Yes it will wire just like the Ofna box. Clip the wires right before they split and solder on a deans plug. You may need to extend the wires for proper spacing. For best results and a starter box that will last 10 years. Remove all the wires and replace with deans wet noodles. Also solder all the wire connections and eleminate all the plugs except for the 1 deans plug that connects to the Lipo. Hard core guys also will pull the switch out and bypass that completely so that the box only works when the battery is plugged in. The more things you remove that can fail, the more reliable and longer lasting your box will be.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 04-22-2012, 08:24 PM   #6
I see, thanks guys... will give that a try.
Old 04-23-2012, 02:21 PM   #7
GTempleton's Avatar
Does any one now where I can buy one? Thank you, George
GTempleton is offline   Reply With Quote
Old 04-23-2012, 06:32 PM   #8
I got mine from Amain but they are out of stock now. That box is like a hot cake man.
http://www.amainhobbies.com/product_...ad-Starter-Box
1/8 TRUGGY OFF ROAD SELL UP Tys91 Australia For Sale/Trade 19 11-19-2012 10:37 PM
1/8 TRUGGY OFF ROAD SELL UP Tys91 Australia For Sale/Trade 16 05-27-2012 05:00 AM
Need better starter box. Dredd Nitro Off-Road 41 09-23-2010 07:57 AM
