Old 04-20-2012, 01:41 AM   #1
Default clutch question
Hello,
I have 2 questions how often do I need to change clutch and clutch springs on a 1/8 off road buggy?
How do you understand that it needs change. I am using aluminium shoes for about 5-6 gallons and I see minimal wear of the shoes.
Is there another aspect that need to check except shoe wear ? How do you understand if the clutch is worn out when driving the car?
I do not understand the boging and sliping terms that i find on the forum, can you please explain.
Another question, I am using ko propo eurus Tx. Do you thing that a drop down wheel is a must for that transmitter?
What will be the benefits of adding one. I am alittle bit concerned about the added weight on the transmitter. how much more
the transmitter will weight?
Thanks...
mike80 is offline   Reply With Quote
Old 04-20-2012, 02:23 AM   #2
curacing2's Avatar
if your getting 5-6 gallons and your clutch isn't worn out please tell us what you are using.
slipping is when the shoes are very worn and small, the motor will need to rev high to try and get the clutch to engage, at that point to you are usually down to the springs touching the bell also...bogging is when the clutch is too early or below the rev range the motor needs to make enough power, it can also be a tuning issue.
If you change the shoes do springs and bearings also, if the inside of the clutchbell is uneven replace that to if you can't dremel it back into shape.
dropdown wheels is just a personal choice and i doubt you would notice the weight
Werks Racing NZ Ltd and Werks NZ team driver, AKA tyres.
Mugen Seiki, Werks fuel, KO Propo, Werks clutches, Bitty Design Bodies.
curacing2 is offline   Reply With Quote
Old 04-20-2012, 07:51 AM   #3
Rock333's Avatar
Trader Rating: 51 (100%+)
+1 Please tell us what clutch you are using to go through that much fuel and not be worn out.
Yes drop down adapters are are comfort add on and are very light so it is just whither you like it or not.
PM for faster response on items for sale.
Futaba
Novarossi
Proline
J Concepts
Rock333 is offline   Reply With Quote
Old 04-20-2012, 10:11 AM   #4
I am using xray clutch. fioroni clutch bell...
B4: V2 Slipper Clutch Question??? racer53 Electric Off-Road 10 04-29-2011 09:44 AM
Mugen MBX6 clutch question? Resqnu Offroad Nitro Engine Forum 13 02-18-2011 04:15 PM
2wd Slash slipper clutch question trytowin Electric Off-Road 7 01-27-2011 07:11 PM
Losi clutch question Marcus Falconie Nitro Off-Road 41 04-17-2009 12:18 AM
Centax Clutch Question nitroaddict Nitro On-Road 14 01-27-2004 05:56 AM
