Old 04-19-2012, 08:18 PM   #1
Trader Rating: 37 (97%+)
Default Servo problem
I was out practicing with my buggy today and my steering servo was acting strange.. It would work for a while and then it would just stop steering, but if you went to move the wheels with your hands the servo still held them there but i had no steering. Happened off and on all day today. I tried my throttle servo for a minute with steering and it worked fine from what i can tell. Also nothing glitches.. my throttle worked perfect all day.. its just my steering servo.. Think i need a new servo or what?
Thanks!
charlesandstuff is offline   Reply With Quote
Old 04-19-2012, 08:23 PM   #2
Rock333's Avatar
Trader Rating: 51 (100%+)
It could be a bad servo motor, but just check your servo saver to make sure it isn't to loose before replacing it. Also check your servo horn to make sure it is bolted down all the way and that none of the splines are stripped.
PM for faster response on items for sale.
Futaba
Novarossi
Proline
J Concepts
Rock333 is offline   Reply With Quote
Old 04-19-2012, 08:26 PM   #3
Its not loose or anything.. its like it looses power or something.
Old 04-19-2012, 08:33 PM   #4
Rock333's Avatar
Try another servo. I have had the same thing happen and it was due to the servo saver being to loose. My friend ran across the same problem and it was a stripped servo saver. It had just enough left to give intermittent loose of steering.
Futaba
Novarossi
Proline
J Concepts
Old 04-19-2012, 08:41 PM   #5
Well when the servo isnt turning the wheels.. it isnt even trying to. It just doesnt react to me turning the wheel on my radio. Doesnt make any noise at all.. No movement. Although it does still hold my wheels straight with force. You think its a bad servo motor?
Old 04-19-2012, 08:53 PM   #6
Rock333's Avatar
OK so the servo still holds but doesn't turn that is either a problem with the servo or it could be a receiver problem as well. Try another servo if it still doesn't work then it is the receiver.
Futaba
Novarossi
Proline
J Concepts
Old 04-19-2012, 10:53 PM   #7
Or it could be your transmitter. Happened to me before. After looking thru all the possible culprit without any problem. I went and open up my transmitter and found out that the steering wheel wire connector was dislodge.
dashstryk3 is offline   Reply With Quote
Old 04-21-2012, 12:13 PM   #8
I got a new servo (servos i was using were 5 years old but still worked really good) and it works again flawlessly, so it was my old servo. I went with radiopost this time and it is amazing so far. Had to overnight it to race this weekend.. bad time for my servo to be going out at the end of the week.. Thanks for all the help :]
Spektrum Steering/break servo problem Shadowhope Nitro Off-Road 30 08-29-2010 07:16 PM
Servo problem or servo saver problem? (DBX) MattFL Nitro Off-Road 16 08-14-2010 05:44 PM
xp 1015 servo problem nitrobhoy Radio and Electronics 30 04-11-2010 07:39 PM
Mini LST2 servo problem... Dragon99 Micro and Mini Scales 8 02-10-2009 10:47 PM
