Old 04-20-2012, 08:07 PM   #16
i like to change mine after every few races.
LosiDriver2.0 is offline   Reply With Quote
Old 04-20-2012, 08:22 PM   #17
coneman's Avatar
i change mine when they feel gritty or dry.
Kyosho MP9 TKI4 / OS Speed Spec II / OS 2090 / Protek / AKA / Futaba 4PL / VP 25%
RC10GT2 FT / OS 15CV / XP Hitec / ProLine / Futaba 4PL / Sidewinder 16%
Sponsor - Visa Platinum
coneman is offline   Reply With Quote
Old 04-20-2012, 11:39 PM   #18
Rsickles's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to Rsickles
IMO changing bearings at a set point (after every X weeks, after every X races, etc) means one of two things... you're wasting money because the bearings may not need changed, or you are waiting too long to change bad bearings. Not all bearings have the same lifespan. If you're inspecting your car regularly during service, maintenance, tuning, check the bearings during these times.
The traditional 'feel test' is pretty indicative of what lubrication is left in the bearing, as well as any foreign matter inside that crept past the seals. One other test is checking the radial/lateral play. Servicing a bearing means nothing if it's out of tolerance... i.e. - sloppy diff bearings just mean sloppier gear mesh on the ring/bevel gears.
Rsickles is offline   Reply With Quote
How often do you....?? Pulse_ Nitro Off-Road 10 03-24-2012 01:34 AM
How offen do you change you air filter?? Do you clean or replace datracing Nitro Off-Road 51 11-22-2009 12:30 PM
How often do you give your car a FULL cleaning? CaptainHowdyt13 Nitro Off-Road 36 06-16-2009 01:08 PM
