Old 04-13-2012, 04:07 PM   #1
Coopz's Avatar
Trader Rating: 22 (100%+)
Default Why is the spur gear so exposed?
Just a question. We took my mates new truggy for a bash at the BMW track, it was cut short after 30 secs when a tiny stone stripped the spur gear. Makes me wonder why the spur is exposed on most buggy/truggy chassis'? Can it not be raised up a few mm.? Why does it need to be exposed?
░▒▓█▀▄▀▄▀▄▀▄-ARCR Member-▀▄▀▄▀▄▀▄█▓▒░
Coopz is offline   Reply With Quote
Old 04-13-2012, 04:44 PM   #2
houston's Avatar
Trader Rating: 91 (100%+)
center of gravity
you can raise it all you want with shims
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 04-13-2012, 04:46 PM   #3
SteveP's Avatar
Fair question, but it's been tried so many ways over the years and it keeps coming back to the simple, open design. The gear is as low as possible for performance reasons. You coule just cut the slot in the chassis part way through, but it just ends up trapping dirt from above and doing more damage. Likewise on the "covering" the gear. Any type of cover adds weight, and they also trap dirt. The gears stay cleaner with a good cover, but once you trap some dirt inside, it doesn't come out and can cause more damage.
In the end, it keeps the costs down, and the amount of weight a proper cover would add to the car has never really made sense.
SteveP is offline   Reply With Quote
Old 04-13-2012, 06:06 PM   #4
There is really no practical way to "totally enclose it" which is the only way the problem is really solved - ie front/rear diffs.
But just as a note I preffer the durango/ae style of having the chassis covering it. But who cares what I want
If your friends don't listen, get new friends
Cheap and fast, not reliable - Cheap and reliable, not fast - Reliable and fast, not cheap
maxflo777 is offline   Reply With Quote
Old 04-13-2012, 07:49 PM   #5
Trader Rating: 18 (100%+)
Jq and AE have a closed chassis under the spur.
David Osborne,
Nemoracing usa
Gofast hobbies,West Virginia hobbies
Amain Hobbies
Fioroni usa
xxxntwv is offline   Reply With Quote
Old 04-13-2012, 08:02 PM   #6
Jaz240's Avatar
Trader Rating: 52 (100%+)
So does Agama
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 04-14-2012, 09:47 AM   #7
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Do you guys have any issues believe most leave open so dirty rocks can pass without stopping the spur
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 04-14-2012, 10:41 AM   #8
Unless your running without a body rocks should never be a problem.
David Osborne,
Nemoracing usa
Amain Hobbies
Fioroni usa
HPI Vorza Flux 1/8 E-Buggy Thread H0LESH0T Electric Off-Road 11249 07-23-2017 01:50 PM
Couger SV2 Thread KostaG Electric Off-Road 1247 01-11-2017 06:21 AM
The YR F2 thread niznai Electric On-Road 33 08-26-2009 12:01 PM
What 4wd buggy is the best kahuna2793 Electric Off-Road 39 03-30-2006 01:46 PM
