Old 04-10-2012, 02:52 PM   #1
Default 1/8 scale tire question
first question is gonna sound dumb but here goes....are tires that are mc/clay compound tires designed to wear longer on clay or provide better traction on clay?secondly..does anyone use the standard open cell inserts anymore and lastly whats with these new wheel stiffeners these days?thanks
HOMETOWN HEATING AND AIR..."THE WAY SERVICE USED TO BE"847-529-5012 24 HRS
Team Durango desc410r,kyosho mp9 tki2
hanker71 is offline   Reply With Quote
Old 04-10-2012, 08:27 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
better traction
open cell foams are waaay outdated, the new closed cells are better in every way
stiffer wheel yields better traction/corner speed IMO
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 04-10-2012, 08:57 PM   #3
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
MC/Clay compounds (natural rubber) are designed to be ran on wet indoor tracks where the clay is near waterlogged. Not all Clay is the same, some tracks require super soft compounds while others you must run Proline MC, Losi Pink, Panther Clay, or Jconcepts Gold it all depends on the moisture content and surface temperature of the soil. Also in high heat areas on dried out/blue groove Clay you'll need to run compounds like proline MX, losi Red, Hotbodies Red or White, or Jconcepts Orange.
Believe it or not, MC/Clay compounds can be is like driving on ice if the track dries out to much...
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 04-10-2012, 08:57 PM   #4
FlatBusted's Avatar
Clay tires will provide the most traction on a clay surface.
Closed cell foams are better in general because they last longer and provide more traction on smoother race tracks. I myself use them everywhere. I don't really use open anymore at all. Sweep Racing Tires makes a nice closed cell that is softer than most others but also provides great traction everywhere.
Stiffer wheels are used on smooth tracks. On a rough track the stiff wheel may cause traction loss.
Tekno RC, AKA, Byron Orginials, PTRC Racing Fluids, North Central Hobbies, Fusion Engines, Houston's Engine Service, BoomRC
FlatBusted is offline   Reply With Quote
Old 04-11-2012, 02:12 AM   #5
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Preety much agree with much of what's been posted,
Never gave a whole lot of thought in the clay compound tires. Better traction? Last longer? I guess it depends on the track. I usually dont have to worry about the clay comounds for outdoor let alone nitro 1/8th, though I'm sure there's places that run nitro indoors.
Closed cell foams seem to be the standard now and there are some that are a little softer or harder if you need it. In general, seem to be the preferred foams just about anywhere.
Wheel stiffeners? Something that is fairly new for offroad. So the jury is still out as to exactly when and when not to use them. I'm told that they help make more corner speed and I would agree that smooth tracks could see the best benifit. Another point that was raised was using them in the heat of the day, when the wheel has the most flex. I hadn't though tof that, but made sence to me that the stiffeners could be used in that manner for tuning.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Teufel Racing is offline   Reply With Quote
Old 04-11-2012, 05:53 AM   #6
wow thanks for the replys guys!i ran my 4wdsc at a clay track last weekend and burned up a set of ss jconcepts in 2 packs!so i need to order 1/8 scale tires and didnt want to suffer the same affects at 75 bucks a set!im new to clay so i appreciate the advise.
Old 04-11-2012, 05:11 PM   #7
imaxx21's Avatar
clay compound is for indoor only, and not all indoor, depends on the clay
-Crash
Old 04-11-2012, 05:45 PM   #8
DBL15's Avatar
also works really well on very wet clay out door tracks , say it rained befoe racing they work well
other then that outdoor should be med compound IMO for 1/8th buggy tyre life is good and grip is not to bad at all
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 04-12-2012, 08:53 AM   #9
jsp619's Avatar
On a hot day i will Jconcepts Golds outdoor as the natural rubber holds up better to the heat than does say an M2 or soft aka compound. Your tire compound choice is gonna depend a lot on ambient and track tempeture the hotter it gets the harder the compound you wanna run and vise versa for the cold. just my 2c's
Xray XB913, NOVA Engines
Associated B5, LRP Speedo, Reedy Motors
Futaba 4PLS
Hi-Tec Servos
jsp619 is offline   Reply With Quote
Old 04-12-2012, 10:00 PM   #10
likeaboss's Avatar
I'm using Panther switch 2.0's.. traction is good and tire wear is very low imho. Indoor clay track that is kept fairly moist. I think they are among the cheaper tires also?
likeaboss is offline   Reply With Quote
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18828 08-07-2017 10:08 AM
1/8 scale buggy and truggy tires sahcamaro Nitro Off-Road 7 02-20-2011 07:44 PM
Yet another 1/8 scale thread: low cost KITs bdcowell Electric Off-Road 12 06-16-2006 08:12 PM
