Old 04-06-2012, 10:27 PM   #1
hayabusafmw's Avatar
Default D8s throttle/steering horns
I have 2 hitecs it's impossible to put aluminum servo horns on the d8s
it rubs on it with the screws & arm setup
is there a kit out there that would fit a hitec servo or should i stick with plastic horns?
thanks!!
www.rcprofile.com
hayabusafmw is offline   Reply With Quote
Old 04-07-2012, 05:59 AM   #2
willbe's Avatar
For throttle the plastic should work fine just make sure you have the right one 24.
For steering, purchase the HB alum one, will last longer.
http://www.amainhobbies.com/product_...4-Hitec-Spline
HB D812, HB D8T, HB D812E, HB D413, HPI Blitz SC, Losi 22 & 22T
Special Thanks to:
HotBodies/HPI Racing, Upgrade RC, OS Speed, Sidewinder Fuels, Hitec
Proudly using: Spektrum DX4R, Viper-RC Electronics, Reedy Batteries, & Pro-Line
Cancer Sucks
willbe is offline   Reply With Quote
Old 04-07-2012, 06:33 AM   #3
Sweet thanks!!! :-)
www.rcprofile.com
Old 04-07-2012, 06:39 AM   #4
throttle they dont make it in aluminum?
www.rcprofile.com
Old 04-07-2012, 07:06 AM   #5
what is weird is that with throttle not adjusted with endpoint the linkages hits the fuel tank hehehe:P
www.rcprofile.com
Old 04-07-2012, 07:16 AM   #6
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
your linkage going to brake cams are too long if they hit the fuel tank..
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 04-07-2012, 06:04 PM   #7
sorry im frech , what are ''cams? ''
Also I did a idle break in tank the motor was running way too hot 250F
I tried to richen it , i never was able to make it spit some fuel.... it was always 240 230 , after a while sitting on idle.....
very weird
I dropped my idle too but that didn't help
www.rcprofile.com
Old 04-07-2012, 08:43 PM   #8
ScottyM's Avatar
Trader Rating: 27 (100%+)
You could also put the steering linkage on top of the servo horn like this..
D8s throttle/steering horns-photo.jpg
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 04-08-2012, 07:14 AM   #9
Thanks will be looking for that
for the temperature issue.... that i really dunno it's the first time i got a car that runs so high & low
yesterday it was like 0 degree outside.... the motor was running like 250F after sitting 20 mins on idle.......
That is non sens so i richen it out.... same result...
very weird
lowered the idle to see what it does
nothing to help the heat....
maybe it's the low speed that someone at factory messed up on setting it ?
www.rcprofile.com
Old 04-08-2012, 07:36 AM   #10
nitroexpress's Avatar
very weird
Why were you idling for 20 min? Don't depend on factory settings, richen that LSN and check your idle gap.
nitroexpress is offline   Reply With Quote
Old 04-08-2012, 08:31 AM   #11
my idle gap is so tiny and it doesn't run on me it's steady but VERY rich so it sounds like crap
Why was i idling , for the first tank i always do that
but with this car i really shouldn't seems like it needs airflow into the head ..
I richen the HSP but it was so rich the performance were crap but i still got some high temp....
maybe it's because the engine it's brand new it will loosen up
www.rcprofile.com
Old 04-08-2012, 11:05 AM   #12
ScottyM's Avatar
You say your idling the first tank, yet you talk about poor performance. If your breaking this engine in then the temps are due to the metal to metal contact of the piston and sleeve touching.
Yet you also state you have poor performance. I guess the question is what are you doing?
Scott Musgrave
Old 04-08-2012, 03:09 PM   #13
sorry for all the confusion i miss lead you
I ran it today factory settings i never reached above 183 190 200 F
So this is GREAT!
idle was great , and everything seemed to be normal! finally
i think my problem was like you said the engine being new + not enough airflow while on idle = overheating almost instantly!
Now it's pretty sweet , i did my second tank today im pretty suprised how much time a tank last!!!
about 30 mins (breaking in half to 1/4 throttle ) still pretty impressive
www.rcprofile.com
