Old 04-05-2012, 05:33 PM   #1
8T
8T's Avatar
Default Tire dressing
After cleaning your tires, what do you put on them? I normaly spray them with sc1 for that new tire shine, but it also helps keep dirt from sticking. Anything better?
tia
8T is offline   Reply With Quote
Old 04-05-2012, 06:03 PM   #2
rider313's Avatar
Trader Rating: 94 (100%+)
I am a simple green guy myself.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 04-05-2012, 06:46 PM   #3
cary's Avatar
Trader Rating: 67 (100%+)
WD40 or simple green here
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 04-05-2012, 07:57 PM   #4
slashracer111's Avatar
Trader Rating: 25 (100%+)
Simple Green.
I believe it takes some of the natural oils out of the rubber, but you wear the tires out before you do anything noticeable.
Hunter Cupp
Be the first, and you'll win -Kimi Räikkönen
HB Racing - JConcepts - Team Orion - Nitro Pro Fuel - RC Addiction Products - Absolute Hobbyz
slashracer111 is offline   Reply With Quote
Old 04-05-2012, 10:16 PM   #5
8ight-racer's Avatar
In between rounds, I wash off tires, then scrub them with a brush, and rewash. Then I blow off all tires really good making sure to blow in the 2 holes of the tires to remove the water in the foam, especially if its your last run of the day with those tires. When they are cleaned up with water and a brush they look fine, no need to spray anything else on them to suck out oils or make tires look shinier, in my opinion.
Palm Desert R/C Raceway - www.palmdesertrcraceway.com
JQ Products, Pro-Line, TKO, Buku, Werks Fuel, Savox, A Main Hobbies, and Uncle Don's Hobbies
8ight-racer is offline   Reply With Quote
Old 04-05-2012, 11:46 PM   #6
MrUnlimited's Avatar
WD40 is what I use.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 04-06-2012, 11:46 PM   #7
Trader Rating: 40 (100%+)
i only use water for cleaning them after the race but for long term storage i spray multipurpose silicone spray to keep them fresh and supple
URL: http://rccebu.blogspot.com/
RCebu is offline   Reply With Quote
Old 04-07-2012, 03:46 AM   #8
Stubbs's Avatar
Trader Rating: 57 (100%+)
I've got the standard "brush in a tupperware container" that I take to the track for between rounds cleaning. I usually fill it with water, plus a little simple green. Tires are scrubbed, toweled off, then set aside until it's time for the next round.
After a race, I give my tires a thorough cleaning in the sink with a 50/50 mix of simple green and water. Again, toweled dry, then set on my work bench overnight to dry. The next day, I put them back in their bags (I store all my truggy tires in those jumbo Zip Lok bags).
The simple green gets them super clean, and keeps the rubber just a little tacky. Heck, my super softs will actually stick to each other if I leave them stacked up.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
What's your favorite tire and what type of track do you run on? MattP Electric Off-Road 21 12-24-2011 11:02 AM
Best tire sauce to keep from packing up? ahsikes Electric Off-Road 21 09-21-2005 05:51 AM
offroad tire "secrets" thedoc329 Electric Off-Road 31 04-29-2005 04:39 PM
