Old 04-05-2012, 02:04 AM   #1
Default tire selction
I would like to ask you, how you select tires.
As far as the type of tire depends on the track and the compound depends on the track temperature?
Lets say the track I am running is about 50-60 degrees on winter and 86-110 degrees om summer.
If I use proline or aka tires what compound should I select ?
m2 or medium for summer and m3 or soft for winter ?
Does the compound matter if the track is hardpacked or not.
The track I am reffering to, is hardpacked on the racing line with a lot of bumps and it has dust on the outside line.
mike80 is offline   Reply With Quote
Old 04-05-2012, 06:17 AM   #2
Joey Powell's Avatar
For me it depends on how much grip is available in the surface itself. I almost always stick to a mid to small pin tire for the consistency. With large pin tires I feel "disconnected" with the track. They also have a tendency to grab the sharp edges of ruts. Large pin tires can be a "safe" tire, but they are rarely a fast choice. If it's hot, the track is abrasive, or has a lot of grip I'll choose a harder compound to either make it last through a main, make the car easier to drive by reducing grip, or both. Usually at night the track temperature will drop, and the moisture comes back up through the track making it slimy and slick. That's when I'll go to a really soft small pin tire. In those cases the abrasion goes away, so I don't have to worry about the tire lasting. For the track you're describing, I'd start with a PL M3/AKA Soft/JC Blue compound in a PL Tazer/AKA Impact/JC Hybrid type tread and go from there. Experiment with compounds. I wouldn't tailor your tire selection to what's happening off the racing line. Just drive the line.
Phin Design R/C (phindesignrc@gmail.com)---VP-Pro-USA---Maxy's Fuel & Engines---TKO Competition Development---
"There are no problems, only solutions."
Joey Powell is offline   Reply With Quote
Team Associated SC8E Thread chuckharrisjr Electric Off-Road 1373 06-23-2017 09:00 PM
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 03:10 AM
Kyosho Lazer ZX5 FS/FS2 Thread desertracerdad Electric Off-Road 3748 05-08-2017 10:56 AM
How to CONTROL your Nerves?????? KWT-NITRO Nitro Off-Road 201 10-01-2010 05:54 AM
