Old 04-01-2012, 11:41 PM   #1
nitro muz's Avatar
Default kyosho GXR28 loses acceleration power after 5 minutes. oil content of fuel?
hi, my first post
im running a 1/8 kyosho stadium truck with gxr28 engine (.28) on glo-max CB 16%.
it runs great for less than 5 minutes, but then loses heaps of acceleration (until i stop it for a bit and start up again) i figured it was getting too hot and running lean, but i cant make it any richer without it stalling all the time.
i was told at hoobyrama that he doesnt stock glomax because of the oil content. could i possibly need better fuel with higher oil content? or less nitro percentage?
or have i got it wrong
thanks
muz
Snow Bro's Racing
XRAY XB8 - Alpha A852 + 2035 - Futaba 9352HV + Protek100T
HB D8T - Tekno chassis & towers - Argus A52 + 2081 (if it still goes) - no servos LOL!
nitro muz is offline   Reply With Quote
Old 04-02-2012, 09:47 AM   #2
TRF801XT's Avatar
Default loss of power
do you have alot of oil seeping through your front bearing? if so, the motor is getting warm, causing it to expand and creating an air-leak. Happened to my stock ofna force .21 motor, junked it for an O.S. also check your rear engine seal, they can leak sometimes, try applying a small bead of RTV sealant to the back case cover. Sound like your describing a leak more than anything, i wouldn't look at the fuel to be the culprit.
TRF801XT is offline   Reply With Quote
Old 04-02-2012, 10:21 AM   #3
nitroexpress's Avatar
Originally Posted by nitro muz View Post
hi, my first post
thanks
muz
Too much oil content. 9 - 11% max. 20 - 30% nitro.
nitroexpress is offline   Reply With Quote
Old 04-02-2012, 10:43 AM   #4
Joey Powell's Avatar
It could be too lean on the bottom, but most likely you're losing compression once the engine heats up i.e. your motor is worn out. The situation you're describing sounds pretty tale tell to me that it's a compression issue. It does NOT sound like a fuel issue. If it were the fuel it would either run right from the beginning or it wouldn't.
Phin Design R/C (phindesignrc@gmail.com)---VP-Pro-USA---Maxy's Fuel & Engines---TKO Competition Development---
"There are no problems, only solutions."
Joey Powell is offline   Reply With Quote
Old 04-02-2012, 10:43 AM   #5
madweazl's Avatar
16% nitro? Does sound like it is overheating, any way of temping it? Car specific fuel? Some of the fuels made for other applications (planes) see more airflow and will run hotter if used in a car. Higher nitro content may bring the temps down as well.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
