Old 03-27-2012, 09:59 AM   #1
j_dogg1970's Avatar
Unhappy takes off
My problem is my sc truck runs off after i start it up could it be the idle is too open..? what could it be?
j_dogg1970 is offline   Reply With Quote
Old 03-27-2012, 10:16 AM   #2
Pop off the air filter and check your throttle linkage. Turn the radio on and set the throttle trim to zero..hit the brake.. if the slide moves, the linkage needs to be adjusted. The idle gap should generally be around .5mm or so.
FLDan is offline   Reply With Quote
Old 03-27-2012, 10:51 AM   #3
Locum51's Avatar
You are correct, after you break-in your idle gap will be too large which will increase the rpm, which then engages the clutch.
If possible, take a pic that shows your linkage setup and your idle gap with all filters and inserts taken out.
DEX210|Reaktor|HK|Onyx
HotBodies D8(OG)=For Sale
Locum51 is offline   Reply With Quote
Old 03-27-2012, 06:27 PM   #4
Once you check the idle if it still does it your clutch may be shot.
Thanks to:
RCHQ (Radio Control HeadQuarters)
ride0012 is offline   Reply With Quote
Old 03-27-2012, 08:00 PM   #5
j_dogg1970's Avatar
Thumbs up
Thanks guys I'm gonna check on all the info that was given..touch base with yall in a minute to let yall know what happen...thanks again helpful tips
Old 04-10-2012, 03:31 PM   #6
j_dogg1970's Avatar
Unhappy
Yea its still happening just racing...any other suggestions I highly appreciate the help....
Old 04-10-2012, 05:01 PM   #7
If all the above already mentioned check out fine, then you may be too lean on the lsn. Try to richen it up a bit.
Mike
Losi 8ight 4.0
Deckman is offline   Reply With Quote
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
SmacTrac...St.Louis Indoor Off Road smac Kansas/Missouri Racing 24520 04-01-2015 03:02 PM
truck takes off when radio is turned off? harris414 Electric Off-Road 22 01-12-2011 01:42 PM
Tags
runs off, takes off
