Old 03-25-2012, 05:55 PM   #1
Trader Rating: 17 (100%+)
Default ofna chrome top starter box help
So i got an ofna glow igniter that i got today. and i hooked it up to my ofna chrome top starter box's power panel and when i hook a glow plug to it. the glow plug does not glow at all. but everything else works. when the glow plug is in the glow igniter the check light on the power panel does come on tho. so any help would be appreciated thank you!
dudemanh is offline   Reply With Quote
Old 03-25-2012, 06:13 PM   #2
ScottyM's Avatar
Trader Rating: 27 (100%+)
The is an adjustment on the power panel to regulate how much power goes through the glow driver. Hook the glow plug and ignitor together and adjust until you get a good glow..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 03-25-2012, 06:19 PM   #3
i did that as well. still no glow on the glow plug at all. but when i hook my multi meter up to the glow igniter it shows its putting out 10.73v when on low and 10.81 when on high setting on the power panel
Old 03-26-2012, 01:19 AM   #4
pravesh736's Avatar
Send a message via Skype™ to pravesh736
there is a adjustment screw on the ignitor box next to the pulg check light .. i think u need to adjust that not only the starter box output
losi eight 2.0/wc team orion/savox/spektrum
losi eight T2.0/clocked werks b5 pro/savox/spektrum
pravesh736 is offline   Reply With Quote
Old 03-26-2012, 04:53 PM   #5
99problems's Avatar
Is the glow plug good?
Don't be a "CYBER BULLY" bring it to the TRACK!!
POINT and PULL!!
99problems is offline   Reply With Quote
Old 03-26-2012, 04:58 PM   #6
Rsickles's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to Rsickles
So you're saying that the glow plug is seeing 10 volts? That's no good.... glow plugs run at ~1.2v - 1.5v or so. Are you wired/plugged in correctly?
Do you have the OFNA part #? Can you post a picture of your power panel with the igniter plugged in?
Rsickles is offline   Reply With Quote
Old 03-26-2012, 10:34 PM   #7
-R2-'s Avatar
THE 10 VOLT READING IS CORRECT it won't blow the plug but I turn the pot to half way. And your plug is bad if you are getting a reading on your meter. That means the circuit closes when you check it. So your problem is the plug, it will spark pretty well when making a connection but will fade after some use.
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 03-27-2012, 11:17 AM   #8
I don't think it's my plug cause I have tested it out on two new os med plugs and also tested the plugs out with my dynamite glow igniter which made both plugs glow.r
Old 03-27-2012, 11:21 AM   #9
Trader Rating: 37 (97%+)
Make sure you have the positive and negative plugged in to the right holes. I wasnt paying attention and plugged them into the wrong holes by mistake and switched them around and worked fine.
charlesandstuff is offline   Reply With Quote
Old 03-27-2012, 11:32 AM   #10
IV tried that and looked at that. Does not matter how I have them hooked up i get the same result. I'm gonna try and call ofna
chrome top starter box pegs? can anyone help cham Nitro Off-Road 6 11-15-2010 10:38 PM
Starter box help Drusillus Nitro Off-Road 17 06-29-2010 01:48 PM
Ofna Chrome top starter box help rcrevolution Nitro Off-Road 6 06-02-2009 09:07 PM
