Old 03-24-2012, 06:03 PM   #1
Default video of taking apart and rebuilding car?
Is there a video of completely taking apart a losi 2.0 on the web somewhere.
Rapala is offline   Reply With Quote
Old 03-24-2012, 09:40 PM   #2
LosiPRRACER's Avatar
probably not, but a manual is very close to a video at this.....
Hotbodies d815 / RCCONCEPT / Savox / Proline / Futaba 4px
LosiPRRACER is offline   Reply With Quote
Old 03-25-2012, 06:27 PM   #3
mikesd1980's Avatar
Trader Rating: 66 (100%+)
What are you trying to accomplish by taking it completly apart?
Mike Diggs
Agama USA buggy
Agama USA Ebuggy - Airtronics M12
Agama A8T Truggy - Hobbyprousa -NemoRacing
"Our perception and attitude toward any situation will determine the outcome"
mikesd1980 is offline   Reply With Quote
Old 03-25-2012, 06:31 PM   #4
I have know idea. I am a newbie and heard guys take their car apart after each race. Just wondering what i need to do
Old 03-25-2012, 06:43 PM   #5
use your manual.... and take it slowly
Old 03-25-2012, 07:31 PM   #6
Don't lose anything. I remember when I first got a Losi, I raced it, took it apart, tried to re-assemble and that stupid spacer that goes between the front bulkhead and steering top-plate disappeared. This can obviously happen with any part from any brand, so take your time and be precise.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 03-25-2012, 08:24 PM   #7
caaraa is offline   Reply With Quote
Old 03-25-2012, 09:05 PM   #8
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Simple rules as you take screws and nuts place back in the disassembled items. Place parts in sections front middle rear use zip lock bags. Makemsure you have some common replacing parts its a waste of time to take things apart not have replcaments if something needs addressing. Use your camera phone take pics of complicated items as reference.
If your going to race you must learn as some stated take our time start with the rear once done move to the center once done move to the front.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 03-26-2012, 05:49 AM   #9
And you don't take the whole car apart! Otherwise you'd have 3000 parts on the table.
For example, (and you may vary a bit) ...
Take out radio tray and engine/pipe. Set aside for separate cleaning with NO water used. Degrease and wash the rest, blow out well with air. Now you have a very clean rolling chassis.
Remove just the front end and disassemble it, keeping all screws laid out in order. Change diff oil / bearings / inspect, whatever you want to do. Then reassemble it. Now you have a whole front end on the table, and the 4 screws to re-attach it to the chassis. You can screw it back onto the chassis at this point if you want.
Same with centre dif, and rear end.
Now you have rebuilt / cleaned / checked (whatever) the main components and all you have to do is screw on the front diff (with arms/shocks etc attached), screw on centre diff assembly, and rear end. Back there you started.......
Refer to the manual whilst doing it though, as some bits go on a certain way (even if they look like they are symmetrical are not!) and some cars use slighly different length screws in different holes, and they look almost the same til you check the manual
Mark _australia is offline   Reply With Quote
Old 03-26-2012, 06:25 AM   #10
Maxxed-out's Avatar
Trader Rating: 15 (100%+)
Tore mine down for the first time yesterday and changed the diff oils and bearings. Its pretty simple, like others have said go from one end to the other and not all at once. I took everything apart, cleaned, changed oil and put everything back together in about 3 hours. I had the manual there for reference. Get some diff oil and bearings before you start taking it apart because if you are going through taking it apart might as well change them out.
Billy Carpenter - Flowood RC
Thanks: JConcepts - CRP, Competition Heat & Competition Suspensions Inc - Fusion X Engines
HotBodies D812 - Tekno EB48.2 - Mugen MBX6T
Maxxed-out is offline   Reply With Quote
Old 03-26-2012, 12:17 PM   #11
Thanks for help guys. What bearings are you replacing?
Old 03-26-2012, 02:21 PM   #12
Rock333's Avatar
Trader Rating: 51 (100%+)
Center diff,F/R diff,Carriers,Spindles. Those are the main ones you would replace if need be. Clutch bearings as well. Just use your own judgment on when to replace if they feel gritty then its that time.
PM for faster response on items for sale.
Futaba
Novarossi
Proline
J Concepts
Rock333 is offline   Reply With Quote
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
