Old 03-25-2012, 03:57 AM   #16
c2k
Mark_Australia.
If you want to start with the rear camber link you might want to change the length of it making it longer .
using the inner hole in the tower and the outer hole in the rear hub.
If the resulting camber changes after you move the camber link position, change the length until camber fits your needs.
BTW i have a very loose track here and i know people run 5-5-5 in their 8.2
Cheers,
c2k is offline   Reply With Quote
Old 03-25-2012, 06:11 AM   #17
John Sullivan's Avatar
Originally Posted by Mark _australia View Post
OK - done a lot more reading and it appears rear upper link location may be best to try first.
Question then - when they talk about moving the rear upper link IN does that mean increasing negative camber? OR do they mean move it in but also lengthen it so camber is not affected?
Similarly when they talk about lengthening the link - do they really mean reduce the negative camber and it is just easier to say lengthen the link?
That is what i would suggest,lengthen rear camber link and lower position on tower it will square up coming off the corner hope this helps
LEISURE HOURS RACEWAY
John Sullivan is offline   Reply With Quote
Old 03-25-2012, 06:34 AM   #18
OK makes sense - lower rear link to get it to square up better, but also lengthen it to get more rear traction.
BUT I am still confused as to whether lengthening it means changing the camber?
Mark _australia is offline   Reply With Quote
Old 03-25-2012, 06:48 AM   #19
99problems's Avatar
Go to a shorter wheelbase
Don't be a "CYBER BULLY" bring it to the TRACK!!
POINT and PULL!!
99problems is offline   Reply With Quote
Old 03-25-2012, 07:28 AM   #20
- shorten wheelbase
- less antisquat
- more rear toe
gt racing is offline   Reply With Quote
Old 03-25-2012, 07:29 AM   #21
Trader Rating: 6 (88%+)
Default Camber
When they say go with a linger rear link that means make it long but adjust your camber to where it was originally
Reds racing USA
AKA
KO Propo USA
Sidewinder fuel
Upgrade Rc
Drip is offline   Reply With Quote
Old 03-25-2012, 07:35 AM   #22
Frank L's Avatar
Trader Rating: 148 (100%+)
Yep
Old 03-25-2012, 11:19 AM   #23
Trader Rating: 45 (100%+)
Pretty irrelevant - and I said standard book setup. The tyres offer the best grip I will get on this track.
All I want to do is make the car oversteer less and I think a few people misunderstood the question........ I know the list of changes I can make and they WILL increase rear traction but many also reduce the ability to square up on power when exiting a corner. I don't want to trade off the latter.
I want to increase lateral rear grip but also square up on power better (it tail wags bad)
WOW ! Just trying to help ya ! The things that I listed are very relevant imo
Good luck !
rc racer 103 is offline   Reply With Quote
Old 03-25-2012, 06:03 PM   #24
Marz's Avatar
On X3 I run front stiffest springs on rear, half rebound, thin shock oil.
Gives perfect amount of rear traction without bogging down the rear too
much.
Hong Nor | OS | Spektrum
Marz is offline   Reply With Quote
Old 03-25-2012, 08:52 PM   #25
Nitro Tiger's Avatar
Im no expert racer but lengthing the rear upper links you are changing the roll centre geometry.
Where the Hudy guide says-Longer link (inner hole on tower and/or
outer hole on hub)
• Decreases rear camber gain
• Increases stability
• Slows down the car‘s responsiveness
Yesterday I had this issue running a setup from another track going back to my local track, hard packed very loose, massive over steer coming out of turns.
I fixed this by lowering rear roll centre ( raise rear upper links), it reduces a bit of steering but had plenty anyway but increase rear traction also not sure on your shock weight from front to back but i had to increase the rear oil WT which helped alot too which helped the wheels to be more planted under throttle.
In the past also found clutch setup is very important on a loose track, I went from a 3x alloy shoe to a 4 shoe running 2x carbon and 2x alloy, made a huge difference so much smoother and progressive on takeoff.
Diff oils play a big part in how your power is being delivered also, I know I have a different car but most guys at my local track run the 553 in the diffs.
Hope this helps
Wade Lazich- NSW 1/8 IC State Delegate.
Thankyou for your support- Werks Racing USA/ Pro Rc Supplies/ Aka Aust./ Ryper Hobbies
LRD- Australian distributor of Werks Race Blend 30% fuel. Dedicated solely to the supply of racing products for 1/8 scale nitro Rc. -lazrd.com.au-
Nitro Tiger is offline   Reply With Quote
Serpent to 1/10th EP Touring Kit S400 rcforum Electric On-Road 3296 05-31-2013 01:48 PM
what's the best way to tame my rear end (8 2.0) mk74 Nitro Off-Road 19 06-01-2011 09:32 AM
Whats the best way to balance your TC? Yokomo_Ant3 Electric On-Road 20 07-21-2009 12:58 PM
New to electric touring ... TC4 + brushless ... tips ? Tabushi Electric On-Road 9 07-22-2008 08:22 PM
What buggy to get B4, XXXCR or RB5? NickPapageorgio Electric Off-Road 31 05-29-2008 01:54 PM
