Old 03-23-2012, 01:57 PM   #1
mikesd1980's Avatar
Trader Rating: 66 (100%+)
Default Looking for a generator for race days. Need help on a model
Dont know how many watts I should be looking for. I need it to support a small air compressor and about 5 or 6 chargers. What do you guy recommend?
Mike Diggs
Agama USA buggy
Agama USA Ebuggy - Airtronics M12
Agama A8T Truggy - Hobbyprousa -NemoRacing
"Our perception and attitude toward any situation will determine the outcome"
mikesd1980 is offline   Reply With Quote
Old 03-23-2012, 02:25 PM   #2
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
2000+watts
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 03-23-2012, 02:27 PM   #3
rdeppen's Avatar
It would depend on how big your compressor is. I'd highly recommend the Honda EU line of generators. If your power requirements are low enough get the EU2000. They are pricey around 1k but worth every penny. They are silent (won't annoy your fellow racers), sip gas (pays for itself long term in fuel savings), have Honda reliability and most important to me when plugging expensive electronics is they have clean power output (no power surges and spikes due to the inverter). If you need more juice you can get the EU 3000 it will run a ton of S$&?
rdeppen is offline   Reply With Quote
Old 03-23-2012, 02:32 PM   #4
Honda would be my first choice
Team Associated, JConcepts, M2C Racing, Big Pimpin Paints
Chris Reilly is offline   Reply With Quote
Old 03-23-2012, 02:41 PM   #5
mikesd1980's Avatar
I was hoping to find a good one for about 500. I will look into the honda EU2000 today. The compressor is small. I think a 4 gallon. I have a 20 gallon for the house.
Mike Diggs
Agama USA buggy
Old 03-23-2012, 09:36 PM   #6
Been looking at some also. The compressor is the draw. The compressor starting up draws alot. I tried on a friends 2000 Honda and it would not let the compressor start. It would trip the circuit. A 3500 would let the compressor run. The compressor is a 4 gal.
Mugen MBX7, Novarossi 21-4C Team, Savox, AKA
Mugen MBX6 ECO "US Version", Hobbywing 150a/1800, Hitec, AKA
HPI Blitz, Castle MMP, Tekin 13.5
Team Durango DEX410R, Castle MMP, Tekin 7.5, Hitec, Jconcepts
*Thanks Mugen for your support*
sjracing is offline   Reply With Quote
Old 03-23-2012, 11:46 PM   #7
JsK
JsK's Avatar
Home depot has the Ryobi suitcase style one that is very close to a
Honda ui2000. 599.00
As others have mentioned the compressor is gonna be a problem with the
small suitcase style inverters.
JsK is offline   Reply With Quote
Old 03-24-2012, 12:56 AM   #8
Champion generators from Lowes.. 3000 watt Honda knock off for 329.00 and has never misses a beat.. even has 30 amp rv out.. and quiet, great for the money..http://www.lowes.com/pd_106885-87012...7C1&facetInfo=
** Scott's Hooker Service** Craftworld and Action Hobbies**Craco Cryogenics** Hotbodies D8T **Fusion X Engines** Byron Fuels ** Hitec Servos ** Spectrum **AKA Tires**
nothin special is offline   Reply With Quote
Old 03-24-2012, 03:41 AM   #9
Stubbs's Avatar
Trader Rating: 57 (100%+)
Do yourself, and those around you, a favor.....don't get an open frame generator (like that Champion in the link). They're noisy as hell......they also suck down the gas, are heavy, and the larger ones are just a general pain to mover around.
Any inverter style generator is MUCH quieter, sips the gas on ECO mode, provides clean power to all of your sensitive electronics, and are very portable. If you have the $$, the Honda EU2000i , or the Yamaha EF2000iS are both an excellent choices. However, there are a few Chinese knock offs that are also decent (Ryobi, Generac, Kipor).
It's more of a crap shoot with the knockoffs though.....you might get a great one, or it could be a lemon. Dealer support, and servicing is going to be limited with them as well. It's a choice you'll have to make for yourself....is the lower cost worth the possible increased headaches if something goes wrong???
I personally have the Kipor IG2000P. Aside from a bad inverter module (1st gen model that had trouble running a heat gun), it's been trouble free for several years, and I run it often at races. I worked with Kipor directly to get a new inverter module, and installed it myself....other than that, it does everything my buddy's Honda does, and it was $400 less.
That 4 gallon compressor you have is going to be a big factor in what generator you get. Most 4 gal. ones that I've seen have at least a 1 HP motor. With startup current, a 2000W generator will not be able to power it. You'd need to step up to at least a 3000W version, with the exception being the Yamaha EF2400iSHC. It has some features built in that allow it to handle the surge current, for very short periods, that would normally trip the circuit breaker.
Honestly though, I'd suggest this Craftsman compressor instead. It's got a .6 HP motor, and is easily powered by any 2000W generator. At $99.99, it's also much less expensive that the jump in price from a 2000W to a 3000W generator. I'd prefer a tank larger than 1.5 gallon, but the CFM is higher than other comparable oiless compressors, and it pumps up VERY quicky. After I got mine, several of my fellow racers liked it so much they also got one. If Sears doesn't have it in your area, it's also sold under the Porter Cable brand as well.
If you get that Craftsman compressor, and a 2000W generator, you should have plenty of capacity for your chargers as well.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 03-24-2012, 04:14 AM   #10
Or buy a really cheap generator, and run off a scuba cylinder for air
Mark _australia is offline   Reply With Quote
Old 03-24-2012, 04:40 AM   #11
Trader Rating: 24 (100%+)
Starting up a 4 gallon compressor will draw anywhere from 1200-1800 watts. Keeping it running will take 700-1000 watts after it's started. You simply then start adding up the wattage of all the chargers running at the same time to get a estimate of what you will be needing. IMO you will need something that will run at 3000 watts and peak out at 3500.
For those that say a open frame gene' is too loud, you need to go home, you probably run electric RC's Besides, if your running 5 other guys, they will understand..
In the end, get something you can afford. Look into a Generac GP3250!
got_nitro is offline   Reply With Quote
Old 03-24-2012, 06:07 AM   #12
Trader Rating: 37 (97%+)
What if you are only using one charger? Is it possible to get a power adapter/inverter and power a charger and power supply from the cigarette lighter?
charlesandstuff is offline   Reply With Quote
Old 03-24-2012, 06:57 AM   #13
Agree. The vast majority of gens at the races are open frame. There have only been a few that I have walked and thought wow that thing is loud. Generac is a good one for sure. I think the one I am going to get is at Sam's. A 3500 for 250.00 or so.
Old 03-24-2012, 10:44 AM   #14
bosshog64's Avatar
I had a frame type genny and they are definitely loud and annoying. The champion isn't too bad for the price, but nothing compares to the quietness and quality of the Hondas! I have the EU 3000 and love it but the 2000's would be all you need.
Take it from me, I use it on my boat for bowfishing and the Hondas are super quiet. When you standing near one all day and especially if you have others around you noise levels are very important. The way I look at it is it will be cheaper than a hearing aid when your older!
-Xray XB9
-4x4 Slash
bosshog64 is offline   Reply With Quote
Old 03-24-2012, 12:33 PM   #15
Agree about the Honda, except trying to prevent this guy from buying a gen that won't run his compressor...I have a similar compressor and tried to run the compressor off a 2000 Honda..It will not run that compressor...Like some have said he could get the Honda gen but would have to get a smaller compressor...
