Old 03-22-2012, 10:01 AM   #1
Default My new body cutter!!!!
As far back as i can remember I've always hated cutting bodies. Trying to get around the edges with those curved scissors really didn't make it any better.
I found something that works so easy I have to share it.
I've had this dremel bit for a while and last week i noticed how well it cut plastic while modding my battery box. I decided to use it to cut out my jc 2.0 losi body.
It was like butter. I had the dremel on it lowest speed and it was smooth and easy to control. I cut the body out in one smooth piece in a little over 5 minutes. It cut so well all I have to do is a little sanding and its done.
Here are a few pics.
My new body cutter!!!!-imag0265.jpg   My new body cutter!!!!-imag0264.jpg   My new body cutter!!!!-imag0263.jpg
Franchise is offline   Reply With Quote
Old 03-22-2012, 10:38 AM   #2
killabud's Avatar
Nice, I might have to try that one. Ive been using the rotozip bit on bodies for a while now. Its the one that looks like a backwards drill bit.
Tom Ulmer Team FISH-DO
---\\\Kyosho MP9 TKI3///---
\\\Futaba|OS Engines|VP Powermaster///
Baby Car!!!!!!!
killabud is offline   Reply With Quote
Old 03-22-2012, 10:44 AM   #3
Trader Rating: 53 (100%+)
Do you have a part number for that bit?
Getting back to racing!!!
See you at the track.
janderson78 is offline   Reply With Quote
Old 03-22-2012, 11:16 AM   #4
Straight from home depot. Lowes should have it also.
Old 03-22-2012, 11:42 AM   #5
Send a message via AIM to nv529
how are you keeping your lines straight?
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 03-22-2012, 11:43 AM   #6
MotoGod's Avatar
Trader Rating: 112 (100%+)
Send a message via AIM to MotoGod Send a message via Yahoo to MotoGod
You can actually use an Xacto knife to achieve the same results using the score and snap method :-) A little more difficult, but same end result really.
Scott Pouliot
Current Race Rigs: TLR 8ight 3.0/3.0E/3.0T/22/22-4
Thanks to my 2015 Sponsors: LutzRC, RadioPost, AKA Tires, RC Addition Products, Nitro Pro Fuels
MotoGod is offline   Reply With Quote
Old 03-22-2012, 11:46 AM   #7
RCmayor's Avatar
Send a message via Yahoo to RCmayor
Score and snap is awesome, a whole lot less mess also.
RCmayor is offline   Reply With Quote
Old 03-22-2012, 11:46 AM   #8
killabud's Avatar
I just get the bulk off with the dremel then use a sanding drum to smooth it all out.
Baby Car!!!!!!!
Old 03-22-2012, 12:32 PM   #9
It's actually pretty easy to keep the line straight with the bit. I was surprised. I use the 90 degree attachment on my dremel. Once the but starts moving let it eat. Don't force it and it almost feels it guide itself.
I cut so slightly beneath the line and when I'm finished I touch up the straight section with my mouse sander and touch up the curved areas with a dremel flap sander.
Old 03-22-2012, 12:35 PM   #10
I have actually tried this method. The problems I had were the curves and once that razor started to go offline you end up wobbles or uneven lines. I don't have surgeon steady hands. Haha.
Old 03-22-2012, 12:37 PM   #11
That "used" to be my regular technique. What I did today was far easier and makes less mess because you don't have nearly as much material to sand away.
Old 03-22-2012, 12:42 PM   #12
killabud's Avatar
Yeah it sure does make a mess. I go outside to do it thats for sure. Ill have to give this method a try though, I have that bit and a body on its way.
Baby Car!!!!!!!
Old 03-22-2012, 12:43 PM   #13
I just finished cutting out my engine hole. So so much easier. Lined up the motor (losi body on d8t) started the bit and in one piece it cut the entire hole. Keep in mind that with the cab forward bodies you have all those angles that need to be removed for the cooling head to fit correctly.
Once it starts cutting its just that easy.
Old 03-22-2012, 12:45 PM   #14
The only problem I had was trying to keep the body at the right angle so the glare would allow me to see the line.
Old 03-22-2012, 01:09 PM   #15
I typically have to cut at least one body a week, (sometimes 2, depending on how much crashing goes on). I cut the first one with scissors and said never again. I have been cutting them with a dremel ever since.
Tony Corley is offline   Reply With Quote
New Traxxas Slash 1:10 Electric CORR Truck salteen Electric Off-Road 3949 03-19-2012 08:24 AM
"NEW" PROTOform R9-F Body daleepp Electric On-Road 288 01-13-2009 10:55 AM
New Corally SP12X Eirik Electric On-Road 325 10-31-2007 09:13 AM
