Old 03-21-2012, 07:13 PM   #1
Trader Rating: 25 (100%+)
Default help with 8ight-t 2.0 rear diff making noise
i have an 8ight-t 2.0 and the rear diff makes a noise when the wheels spin. it sounds like the pinion and gear ring but its not skipping and when i installed it after taking apart the rear diff/rear drive shaft, i pushed the pinion from the inside flush to the inner bearing and mounted the shaft coupler flush with the outer bearing so there is no play. i heard this noise before i re did my diff fluids so i am just trying to find out what is wrong and why its making a noise like someone put a card to a spinning bicycle rim. thanks
jdtwenty6 is offline   Reply With Quote
Old 03-21-2012, 07:24 PM   #2
madweazl's Avatar
If you're getting a clicking kind of sound, you probably need to replace the ring/pinion gears. They wont look particularly bad but will fail pretty quickly if this is the case.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 03-21-2012, 07:43 PM   #3
the funny thing is that ill have the diff hooked up to the drive shaft and spin the front wheels and it sounds fine(quiet) but when i throw the shock tower and a arms and tires on, it does it. how can i be sure this is what it is? is this the only thing it can be, i just dont wanna go buy a 40-50 ring gear/pinion set and it still sounds the same.
Old 03-21-2012, 07:58 PM   #4
Team_Orange's Avatar
im not sure how true this is but i was told that when it starts making that noise change the diff case and re shim again.
NITRO PRO FUEL--FUTABA--O.S. ENGINES--Hobbico-AKA-Rcaddictionproducts.com
Team_Orange is offline   Reply With Quote
Old 03-21-2012, 08:12 PM   #5
anyone else have this noise? i want to race this weekend and i dont know if i will end up breaking down or something.
Old 03-21-2012, 08:46 PM   #6
Trader Rating: 50 (100%+)
It is definitely the ring and pinion. Replace the gear box/bulkhead, pinion and ring gear, diff case and bearings. Its better to be confident that you won't have a problem.
Make sure to shim the new ring and pinion and check it often.
Pre-Loaded
ForwardBite is offline   Reply With Quote
Old 03-22-2012, 04:56 AM   #7
Trader Rating: 68 (100%+)
That's standard equipment on the Losi 8T.
Dealer for Serpent, Intech, Agama, Pro Speed, JQ Products, Tekno
Alpha,Triton, Picco, Reds, Go, Arrow,Bullitt,Beta
Sponsor- Nemo Racing.
Greg B is offline   Reply With Quote
Old 03-22-2012, 06:32 AM   #8
Integra's Avatar
Still on my 1.0 gear's.
Old 03-22-2012, 07:23 AM   #9
t0ddy_44's Avatar
All of the above plus when you shim the rear diff, shim it tight as you can without binding.. The sweet spot is you will feel a tight spot and then it will loosen as you revolve it
A good upgrade is the aluminum diff inserts, they will help keep it tight!!
t0ddy_44 is offline   Reply With Quote
Old 03-22-2012, 11:49 AM   #10
Tear it apart and find the problem. I could be shimming, it could be bearings, it could be a old diff case, it could be that the drive shaft is not all the way on the pinion.... The only way to find and fix a issue is to wrench on your ride man.
token is offline   Reply With Quote
Old 03-22-2012, 07:25 PM   #11
Trader Rating: 48 (100%+)
The other noise you could be hearing is the out drive about to seize up in the diff case. Pull it apart and put some hi temp hi pressure grease on the out drives and re assemble.
Up in the air...
Cyberacer is offline   Reply With Quote
Old 03-22-2012, 10:47 PM   #12
Yep.
Franchise is offline   Reply With Quote
Old 03-22-2012, 11:17 PM   #13
merdith6's Avatar
Default well
Maybe there is something in the spokes (gears). Take an exacto blade and slide it in each groove of the gears and get all the dirt out. Just an idea.
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Getting started:Tip's,Trick's,Newbie's come here! xsxracing Rookie Zone 59 01-03-2009 09:57 PM
